DIY: Spark Plug Install
Old May 22, 2003
  #31
Bartkat's Avatar
LOL
I don't give a damn what anybody says, my Civic ran smoother after I put in the Iridium plugs. There is no doubt in my mind that they work better than the platinum plugs that come in the oem in the car.
Old May 22, 2003
  #32
Bartkat's Avatar
Originally posted by wonderz
since we are on the subject of spark plugs, will silver have more electrical and thermal conductivity than platinum and iridium?
Yes and so would copper. But neither will last very long.
Old May 22, 2003
  #33
Bartkat's Avatar
By the way. I traded for a Lexus IS 300 and it comes standard with Iridium plugs. So I would have to say that if they are good enough for Lexus, they certainly ought to be good enough for a Civic.
Old May 22, 2003
  #34
dj pyrotechnics's Avatar
dj pyrotechnics is an unknown quantity at this point
lol Kairi... a few of the things he said kinda sounded like it, but you pointed out a whole lot more than i noticed!
Old May 22, 2003
  #35
Bartkat's Avatar
I'm not sure how to do the "turn several revolutions" part.
Old May 23, 2003
  #36
solar's Avatar
solar is an unknown quantity at this point
Originally posted by Bellz
First of all, I don't have a VTEC motor. I have the DX.
Secondly, who cares? The same argument can be said for 90% of the things we do to our cars. Did you REALLY need a body kit? Probably not. Did you REALLY need to swap a Type-S motor? naahh.
The point here is we like working on the car and personalizing it. Go take a chill pill.
I don't think I'm the one that needs to take a chill pill, BTW what is that Xanex or Prozac? I was just making a point that you don't "have", yes I said "have", to change the plugs for 100,000 miles, thats all. You can change them every week and paint your car pink with glitter as far as I care. I was just giving out my observation and trying to save you a couple bucks, thats it.
Old Nov 19, 2003
  #37
Dticalman01's Avatar
Dticalman01 is an unknown quantity at this point
The four valve coverings are hot whenever after I drive...is this because my Awesome Bosch Spark Plugs aren't tightenend hard enough..?
Old Nov 19, 2003
  #38
Bartkat's Avatar
Do you mean the coils that sit on top of the plugs? Actually, everything on or near the engine gets hot while the engine is running, and takes a while to cool off.
Old Nov 19, 2003
  #39
But it seems like the temperature under the hood of my car is getting hotter..therefore the performance of my car is sucking...Should I just add more coolant to solve the problem?
Old Nov 19, 2003
  #40
Bartkat's Avatar
Don't add coolant unless it's low. Did you check it?
Does the hot light on the instrument panel come on?
Is your fan working ok?
Check all that stuff out.
Old Nov 19, 2003
  #41
No, but the temperature of my car is higher than it used to be....i mean b4 it was like at the bottom line and it performed well....but now it's right on the middle line now..I want it to be cooled down like before..how would I be able to make the engine go cooler?
Old Nov 20, 2003
  #42
Bartkat's Avatar
Take it to your dealer and have them check it for you.
Old Jan 12, 2004
  #43
draganjr's Avatar
draganjr is an unknown quantity at this point
which one is the best spark plug to get?
plat.
or
iru. ?
Old Jan 12, 2004
  #44
Bartkat's Avatar
The best I know of is Denso Iridium.
Most Cvics come stock with platinum.
Old Jan 12, 2004
  #45
C2i0v0i1C's Avatar
SuperMODrizd
what bothers me here, is the two prices i have seen, 52 and 48, holy crap, i paid 15 bux for my NGK and they aint stock in any form, and thats 15 bux and in the motor
Old Jan 12, 2004
  #46
Bartkat's Avatar
They worked for me. If you don't want to buy them, that's up to you. c
Old Jan 12, 2004
  #47
acidbaby's Avatar
The Beez Kneez
i have bosch platinum 4's and i love em
Old Apr 20, 2004
  #48
zen_master's Avatar
DUDES
PLEASE HELP ME..
every time i read a thread about spark plugs...i got confused..
NGK IRIDIUM IX
OR
DENSO IRIDIUM
damnnnnnn...so hard to decideeeeee...which one is better?
platinum is definitely out of my way..
GREAT GREAT DIY. IM GOING TO CHANGE MY OWN PLUGS. HAHHAHAHA
anyway, why didn't you use a torque wrench????
Old Apr 20, 2004
  #49
Bartkat's Avatar
I like the Densos.
You don't need a torque wrench because you tighten the plug till it stops and then just give it 3/4 turn to seat it.
Old Apr 20, 2004
  #50
zen_master's Avatar
Originally posted by Bartkat
I like the Densos.
oh damn...i got no gut...
no experience that is....i'll stick with torque wrench...hahaha...gonna borrow it from my uncle...
damn....now u said denso....but some people say NGK's better..
Old Apr 20, 2004
  #51
Everyone has told me hondas like NGK. That's what two dealership tech guys have also told me. And the stock plugs are duoble platinum, which technically are better than iridium because both electrodes are platinum. With iridium, one is nickel. Iridiums are still good plugs, though. Buy a torque wrench so you don't mess up your engine like I probably did.
Old Apr 20, 2004
  #52
Bartkat's Avatar
Denso was the first one to come out with irridium and my car had Denso platinum for stock. Get a set of one or the other and if you don't like them, get the others. It's not that big of a deal.
Old Apr 20, 2004
  #53
zen_master's Avatar
huwa..
damn, now there's a debate...... NGK or DENSO in my heart.....
hmmmmmm..
anyway, gearbox...u said we got double platinum?? man...since when? is this true?
NGK....DENSO....NGK....DENSO....NGK....DENSO....NG K....DENSO....NGK....DENSO....
arhhhhhh...
Old Apr 21, 2004
  #54
draganjr's Avatar
i am going back to stock platinum because the iridium seems to make the car not run all that good (hard to explain)! Stick with stock!
Old Apr 21, 2004
  #55
Bartkat's Avatar
That's strange. Mine seemed to just run smoother with the iridiums. Did you get the correct heat range?
Old Apr 21, 2004
  #56
FALKEN's Avatar
Civicforums Junkie
im running Bosch Platinum +4s ($4.99 each)
Old Apr 21, 2004
  #57
zen_master's Avatar
yeah, i don't think there's any problem with goind back to stock....
stock's plugs are not that bad at all.....they're platinum too...
but i think i'll go with iridium.....
Old Apr 21, 2004
  #58
draganjr's Avatar
heat range is good and i might go to Bosch Platinum +4s too.
i have those in my Acura Integra and it runs smooth!
Old Apr 21, 2004
  #59
HyaBoosta's Avatar
wow if you need a diy for a spark plug change then your shouldn't be touching anything on yourself.
Old Apr 21, 2004
  #60
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've heard of the Plus 4's little tips breaking off and going into the motor. I don't know if it's a myth but it could happen. Other than that I like those plugs, they make some cars rip.
P.S. I have Denso's!
