NEED HELP !!!!!!!!!!!!!!!!!!!!!!
Old Jun 13, 2002
Incapearl01's Avatar
Incapearl01 is an unknown quantity at this point
I need to find out how to remove the cruise control, mirror assy, switch panel so I can change the color of lights. Also, when I changed the lights in the 3 bottom buttons (AC,circulate,and amount) I found the orange flat pieces of plastic but couldn't find the 2 orange, and 1 green lights that are right above them.[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jun 13, 2002
Duckor's Avatar
Duckor is an unknown quantity at this point
i remember someone posting pictures of this, i heard they had a hell of a time trying to get to the light in either the cruise or moonroof.
i remember they almost broke the thing. try a search a few times for led, cruise, or help?
dunno, just a suggestion, i've never done this before.
Old Jun 14, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
I posted this at one point, but not sure where it ended up. The trick to the mirror/cruise assembly is this. Open your change compartment and inside you'll find one screw - use a philips head and take that out. Then, just get a hold of it and give it a good pull. It will come right off. Might take a little effort but it will, trust me. Then you can take off the assembly's for each of the three switches. I did mine to blue and they look sweet ...
Also, for the circulate/AC/rear defrost buttons, there's a small clear plastic piece above where the orange 'filter's' were. In behind them are the three LED's, and I think they're mounted from the side. It's been a little while since I had it taken apart, but they should be right above where those orange pieces. Lemme know if you need any more help. Also, I'll PM this info to you as well ..
