How hard is it to adjust the height on coilovers?
Old May 28, 2002
Rollin0n18s
Guest
Posts: n/a
I'm thinking about buying some coilovers but was just wondering is it hard to adjust the height and how exactly do i do it
Old May 29, 2002
Toretto's Avatar
Toretto is an unknown quantity at this point
no its easy, you count the treads on the sleeve
and thats how you can tell, thats how i do mine...
Team Turismo
Old May 29, 2002
YanYan's Avatar
YanYan is an unknown quantity at this point
I HAVE ground control AND I FOUND THAT IT'S hella HARD TO ADJUST THE HEIGHT OF THE FRONT. It seems like it stucks and the shock plate is on the way blocking my view. Cannot put the key into the hole. could somebody teach me how to do it?
Old May 29, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
<< I HAVE ground control AND I FOUND THAT IT'S hella HARD TO ADJUST THE HEIGHT OF THE FRONT. It seems like it stucks and the shock plate is on the way blocking my view. Cannot put the key into the hole. could somebody teach me how to do it? >>
The front ground control coilovers are a bit harder to adjust - you just have to jack the car up a bit higher to be able to reach the locking perch.
Old May 29, 2002
<< I'm thinking about buying some coilovers but was just wondering is it hard to adjust the height and how exactly do i do it >>
Well you have to jack up the car so that the wheel is off the ground. So it's not like you can stop your car before a big speed bump, adjust your coilovers, and be on your merry way. With Ground Control coilovers you just use an allen wrench to unlock the perch, then you rotate the perch to raise or lower the car. Simple as that.
Old May 29, 2002
Toretto's Avatar
ok, i got GC, have you read the Honda Tuner where
it shows you how to install the GC?
the perch that youre stock springs used to sit in has to cut off
so when you slide the GC sleeve over the strut, you have
nothing blocking your view and you can get the alan wrench
in there and oh ya when you cut the perch leave a little bit of metal
around so the sleeve wont slide down the strut...
its easy..
Hey you
Old May 29, 2002
Toretto's Avatar
ya like he said!
Old May 29, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Like both of them said....[IMG]i/expressions/laugh2.gif[/IMG]
Old May 29, 2002
YanYan's Avatar
but after you cut the perch, you can't use H&R or Neuspeed springs anymore, rite?!
Old May 29, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
the body shop next door 2 my work said gc's suck
Old May 29, 2002
Toretto's Avatar
actually if you know what your doing GC
are the ****, 1 locking perch=using 1 hand to twist up or down,
2 locking perches=a pain in the A$$....
lol
GC
Old May 29, 2002
sadboy916's Avatar
toretto cmon dont use f & F quotes thats g@y
Old May 29, 2002
CivicRacer18G's Avatar
CivicRacer18G is an unknown quantity at this point
I know the skunk2's are really easy to change the height on. They ride really well too.
Old May 29, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
what does a body shop know that a import shop will not. They are probably talking about the bouncy ride the gc give. Well, like most people, they lower there car without changing the shocks. The stiffer the springs, the stiffer you need the shocks to be or a bouncy ride you will have. They are not shocks absorbers b/c they do not absorb road shock, the springs do. "shocks" are really dampers and dampen the bounciness of the springs.
Thats my two cents.
Saving up for JIC coils. Just got a new job and I do 1/10 of the work(of my old job) and only get paid 50 cents less.
Old May 29, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
the skunk2's are easy to adjust [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]..but they are a little bouncy...i like em tho you bounce a lot w/ these factory shocks but i dont care i think it is coo[IMG]i/expressions/laugh2.gif[/IMG]
SoslowEj666
Mar 8, 2016 01:10 AM
JetsterDajet
Aug 15, 2015 08:07 AM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
Jul 12, 2015 11:54 AM
