engine and tranny swap questions
Old Aug 12, 2010
96hondacivic123's Avatar
96hondacivic123 is an unknown quantity at this point
i own a 96 honda civic. i dont know much about imports more of a chevy truck guy, but love imports at the same time. my tranny has recently went on me so im looking into doin a engine swap n tranny rebuild or swap. was wonder wat type of engine i should swap into it, along with wat tranny. im looking to in the future to add a turbo
Old Aug 12, 2010
02civicsi02's Avatar
Low and slow!
Re: engine and tranny swap questions
Best choice of swap would be a b series or k series.
Old Aug 13, 2010
is there anything special i need to buy motor mounts etc etc.....
Old Aug 13, 2010
Low and slow!
Yes with a bseries you will need the motor/ttranni, ecu, wire harness, motor mounts. With a k series you will need alot more, you will need motor/tranni, ecu, wire harness, motor mounts, ep3/dc5 subframe/lca, ep3 sway bar, fuel pump, dc5 shifter assembly/shifter linkage, and I think a couple other things. But k motor in older civic = beast.
beneditti
Jan 15, 2016 12:31 PM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
McD
Apr 22, 2015 05:28 PM
supercivic01
South
Nov 30, 2001 11:27 AM
