Are JDM and USDM parts interchangable?
Rep Power: 0 Are JDM and USDM parts interchangable?
Ok im going to replace a few parts that im pretty sure are bad on the car i just bought. The car is a 99 civic ex with an obd1 jdm b18c gsr motor and tranny. I want to replace the idle control valve, the fast idle valve under the throttle body and the vtec solenoid. Right now the car has a sohc vtec solenoid valve that has been having intermittent problems. A few times ck engine came on and vtec didnt work. As soon as i turn car off and back on ck engine off and vtec works. Only did this a few times. Now what car do i need to get a idle control valve and fast idle valve from? A 94 GSR b18c or something else? If someone knows i would greatly appreciate it.
Rep Power: 787 Re: Are JDM and USDM parts interchangable?
the jdm motors do have different parts compared to usdm, so im not sure that you can just buy usdm parts and expect it to work. their engines are different over there and alot of times even a motor from the same car as here will work differently (higher compression, needs better gas, different vtec engagement, etc). try to find parts off the same motor type.
KillerX
04-09-2017 08:20 AM
Supramk3
06-11-2015 11:13 AM
