91 Civic DX help
91 Civic DX help
i am having issues with it starting. it won't start at all. i have checked the timing, coil, new distrib cap, rotor, plugs and wires, and the compression seems to be good. it gets plenty of fuel. it has me dumb founded. any ideas?
Re: 91 Civic DX help
does it turn? does it fire? do you hear fuel pump prime when you turn the key (not all the way to start position) details please
the engine does turn. i have blue spark from the plug wires. new plugs. the fuel pump does run. main relay checked fine. no codes from the computer. still lost on what it could be
probed the negative terminal on the coil to body ground and it shows the negative terminal havin power. is this good or bad.
UPDATE...took the igniter to autozone to be checked. tested good. pick up coil is fried in the dizzy so i need a new one
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
