exhaust leak help needed
Old Dec 17, 2009
laack's Avatar
laack is an unknown quantity at this point
I just replaced the donut gasket in front of the catalytic converter and its leaking. Did i need to use a sealant around the gasket? The bolt/springs from autozone didnt seem to pinch the flange tight enough against the gasket to seal... will the gasket seal it self up a little more as it heats up?
94 civic dx 1.5l
stock exhaust
Old Dec 17, 2009
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
Re: exhaust leak help needed
did you tighten them with hand tools, or air? Sometimes the only way to get the flanges snug enough are by using impacts.
Old Dec 17, 2009
laack's Avatar
hand tools...
its tough to explain, but the bolt shaft had a long bushing spacer type set-up with the spring. the threaded portion was only about 3/4 inch. i tightened it to the point where the spacer was hitting the a pipe. the pressure applied to the joint is from the spring pusing against the cat flange and the head of the bolt. It cant be tightened any further.
I'll find a link later and post it. i have to step out for a few hours
BootyDo
May 7, 2015 04:46 PM
mievil
Apr 28, 2015 11:02 PM
superstanko
Apr 28, 2015 04:38 AM
Myredjonda
Apr 14, 2015 07:00 PM
Lightman
Nov 10, 2001 06:44 PM
