engine swap
Old Jul 18, 2009
ghostjhr's Avatar
ghostjhr is an unknown quantity at this point
engine swap
i just did an engine swap.went to start it up and got nothin.. i need some helpo
Old Jul 18, 2009
JagerVR4's Avatar
JagerVR4 is an unknown quantity at this point
Re: engine swap
check all wires and connections to sensors. check your starter and make sure the battery has charge
Old Jul 18, 2009
ghostjhr's Avatar
Re: engine swap
will a bad ground stop it from starting/i did a swap from a d16y7 auto trans to a d16z6 mannel trans/ so and igs like no power is getting to the starter. iam lost when it comes to wireing
Old Jul 18, 2009
JagerVR4's Avatar
Re: engine swap
yeah, make sure all grounds are secure.
Old Jul 18, 2009
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
Re: engine swap
a bad ground is a very big deal and will definitely cause problems with starting. Make sure all the connections are tight and clean. Do you know how to use a test light or multimeter? if so start testing your connections with one of those.
Old Jul 18, 2009
ghostjhr's Avatar
Re: engine swap
how many.grounds.r on a z6 and were r they at
Old Jul 19, 2009
You VTEC...I-VTEC
Re: engine swap
im guessing 3 like most other hondas battery to transmission, transmission to chassis, and I cant think of where the third would be but i think there is one. do you have power to anything such as lights? if not i would say take a look at your fuse box and make sure you reconnected that power.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
