Honda Civic 1992-1995 EG and EJ Valve Clearance
Click on the link to see the complete article with images check it out here: Honda Civic Valve Clearance EG and EJ. Garage411.com
B16A Dual Overhead Camshafts (DOHC)
1. With engine cold, remove upper timing belt cover, valve cover, spark plugs and distributor cap. Adjustment of exhaust and intake valves are done at same time.
FYI: On some applications, the word UP will be cast into the camshaft pulley. On other applications the UP mark will be represented by an arrow pointing to the outer edge of the camshaft pulley.
2. Rotate crankshaft to bring piston No. 1 to TDC on compression stroke. UP marks on camshaft pulleys should be at top, and TDC grooves on camshaft pulleys should align with cylinder head surface. Distributor rotor should point to spark plug wire No. 1 on cap.
3. Loosen lock nuts on valves for cylinder No. 1, and adjust valve clearances to specification.
4. Tighten valve adjuster lock nuts to 15 ft. lbs. (20 N.m). Recheck valve clearance. Readjust valve clearance, if necessary.
5. Rotate crankshaft counterclockwise 180 degrees. Ensure cylinder No. 3 is at TDC. Adjust valves on cylinder No. 3. For remaining cylinders, repeat steps 3) - 5).
6. Replace valve cover and distributor cap. Tighten timing cover bolts and valve cover crown nuts to 7 INCH lbs. (10 N.m).
Single Overhead Camshaft (SOHC)
1. With engine cold, remove timing belt upper cover, valve cover, spark plugs and distributor cap. Adjust exhaust and intake valves at the same time.
2. Rotate crankshaft to bring piston No. 1 to TDC on compression stroke. UP mark on camshaft pulley should be at top, and TDC grooves on camshaft pulley should align with cylinder head surface. Distributor rotor should point to spark plug wire No. 1 on distributor cap.
4. Tighten valve adjuster lock nuts on D15Z1 or D16Z6 engines to 14 ft. lbs. (20 N.m). On all other applications, tighten valve adjuster lock nuts to 10 ft. lbs. (14 N.m). Recheck valve clearance and repeat adjustment, if necessary.
5. Rotate crankshaft counterclockwise 180 degrees. Ensure cylinder No. 3 is at TDC. Adjust valves on cylinder No. 3. For remaining cylinders, repeat steps 3) through 5).
LionSpratt
Jan 29, 2017 11:07 PM
jessicakaybby
Apr 20, 2015 12:11 PM
