Can sombody confirm that this is the wrong harness for 07 civic fog lights
Old Oct 25, 2008
Shroomy07cex's Avatar
Shroomy07cex is an unknown quantity at this point
This is the harness they gave me that goes underneith your dash and hooks up to the button and fuse box. But im fairly certain they sent me the wrong one. Because i've looked at Honda's installation instructions and this does not look like the harness they say i need.
Old Oct 25, 2008
manahoonie's Avatar
Re: Can sombody confirm that this is the wrong harness for 07 civic fog lights
where did you get your fog lights from?
with the green connector on there, it appears to be an ebay kit...thus probably not actual 'OEM' but 'OEM Style'
if that is the case, then you can only use the OEM instructions as more of a 'guide' persay...
have you layed the set-up out on the floor, and 'assembled' it outside of the car, so you know what everything connects up to?
feel free to PM me or find me on a messenger if you need some help!
Old Oct 25, 2008
theres no way thats a honda harness. i would just start over and make your own.
Old Oct 26, 2008
manahoonie's Avatar
well, if it was like the one i got, it should all plug up... just slightly different...
here's what i did with mine i got off ebay (esuse)
just lay it out, plug everything together that does match up.
then take a look at the plugs you have left...
use the OEM diagram to see where their harness plugs into the car, and compare to your harness for matching plugs. be sure to find some grounding points for the metal C-clip ends...
it should work just fine then.
like i said before, i'm more than willing to help you out with plugging it in. (i'd help you install, but i doubt you even live in the same state :P )
Old Oct 26, 2008
thewal's Avatar
thewal will become famous soon enough
it's the same harness that i got for my fogs. Brown and white connectors plug intot he fuse box. smaller white connects to the harness running from the fogs. green to the switch.
the switch should light up when you turn your normal lights on.
PM me if you need help.
Old Oct 26, 2008
ahdo1987's Avatar
ahdo1987 is an unknown quantity at this point
well. i think this is not wrong.
but just the plugs won't plug in correctly.
please refer to this link. there is a tutorial for the exact same thing but on the other forum.
please warn me if i m not suppose to do this.
http://www.8thcivic.com/forums/light...gs-wiring.html
Old Oct 26, 2008
Talking Re: Can sombody confirm that this is the wrong harness for 07 civic fog lights
Thanks alot guys, all of this has helped me alot. Now i'm trying to decide if i want to put this one in or if gearbox is right and just make my own harness. I'll get back to you guys when i have it in to tell you all what happened.
Thanks
Old Oct 26, 2008
well at least try the one you have. if it works, you saved some time and money
Old Oct 26, 2008
manahoonie's Avatar
yea, i didn't think 8thgen had a DIY for that exact set-up (at least it looks the same)
go with that one first
mine was ebay, but following similar diagrams, i was able to find where the plugs go in the car...not the same wire set-up (so they actually can come on at other times the OEM ones don't) but plugs up the same...
Old Oct 28, 2008
How do i take the cover off the blue fuze harness??? i can't get that off and thats the only thing stoping me from being finished. Thanks
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
disaster
Nov 7, 2001 05:30 PM
