Help me locate this part?
Old Aug 28, 2008
silverem2's Avatar
Question Help me locate this part?
Wow! Long time since I have posted on these forums. Anyhow, I have a question regarding a part I need for my Honda. It is located underneath and looks like a pressure valve piece for the EVAP system. It is broken and inside it does indeed move up and down. If someone could help me locate this part on Hondaautomotiveparts.com, that would be GREATLY appreciated.
Attached are a few pictures:
Old Aug 28, 2008
Re: Help me locate this part?
well the big cylinder piece is the air filter, i wouldnt recommend changing it til 100k miles. im not sure what the circled part is tho, have you tried taking it off? is the engine light on for evap emissions? alot of times a new gas cap will fix it.
Old Aug 29, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
http://www.hondaautomotiveparts.com/...L+TANK+%281%29
the piece is next to one of the # 37's but in order to get that piece you are going to have to order #20
Old Aug 29, 2008
silverem2's Avatar
That's what I thought as well, and I don't want to order that whole deal if I don't have to. The CEL is on for EVAP issues gearbox, but that piece being broken might have to do with it. I just bought and replaced the gas cap, but it hasn't gone out and I've driven about 40-50 miles already. Should I reset and see if it comes back?
Old Aug 29, 2008
yeah reset it first, otherwise it may be one of the valves near the tb. OR, i bet if you have an aftermarket intake, the evap hose that sits on top of the pipe finally got a hole rubbed into it. its a very common problem.
Old Aug 29, 2008
silverem2's Avatar
Its definitely in the bottom. It was the EVAP code problem with the canister area? I don't remember the code but it was in relation to that. Also, I don't have an aftermarket intake.
Old Aug 29, 2008
well it might be the charcoal canister gone bad. do you top off at the gas station after the pump clicks off? if you do, theres the problem. need a new charcoal can
Old Aug 31, 2008
silverem2's Avatar
I try not too, but I'm sure I have before. Which part number is it on the hondaautomotiveparts.com?
Old Aug 31, 2008
04 Honda Civic's Avatar
hmm what can happen if i do this?
i do this all the time so i guess its not good..?
Old Aug 31, 2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
"it can damage the vent system saturating the charcoal canister." - per my google search.
stryder12
Jun 30, 2015 08:33 PM
vtec_concept
May 24, 2015 10:27 AM
Rushfan1
May 6, 2015 01:20 PM
Streetlife
Nov 9, 2001 05:06 PM
Streetlife
Nov 8, 2001 05:31 PM
