My Power Locks kinda stop working
Old Apr 25, 2008
tamazoid's Avatar
tamazoid is an unknown quantity at this point
Hi! I don't really know how to explain it, but my power locks for my 01 Civic kinda stop working. It's the drivers side that I have problems with... I notice that it only works once or twice every minute. The passenger side works everytime. I don't know how long it's been doing this for, but I just started to notice it now.
Now I'm thinking there's shouldn't be anything wrong with the connection cause it works once or twice every minute. Could there be something wrong with the actual power lock itself? Any help or suggestion is appreciated! Thanks!
-Andrew
Old Apr 26, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: My Power Locks kinda stop working
does it make a loud noise when doing it or does it just not work at all? if it makes a loud noise then either the actuator is broken/damaged. have you done anything to your headunit? i found out that somehow the headunit is related to the power locks. i guess part of the power locks harness goes through the headunit harness as well.
Old Apr 26, 2008
sl33pyriceboi's Avatar
^yes, search actuator on this forum and you find DIY and alot mroe info on replaceing it.
i replaced mine a few weeks ago, so if u have any question on anything feel free to ask.
also if u order the actuator, i suggest you order the whole assembly... its not much more and it makes life hella easier
Old Apr 26, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
probably the most notorious part for dying on are cars they just don't last
Old Apr 26, 2008
tamazoid's Avatar
It makes a noise when I use it. Even if it doesn't work. It's just weird how it works one or twice every minute...
Yea, I also did read that it was a common problem. Oh well...
Old Apr 26, 2008
spudz904's Avatar
spudz904 is just really nicespudz904 is just really nicespudz904 is just really nicespudz904 is just really nice
its the actuator, had the same problem. There a DIY somewhere on here
Old Apr 26, 2008
greeen01civic4d's Avatar
actuator, there is a tsb for it, just order one, its 25 bucks, and takes about 1-2 hours to replace, just do it, trust me, i did mine, itss common
Old May 2, 2008
nicokpe's Avatar
nicokpe is an unknown quantity at this point
yes actuator, same problem about that. you can replace it
roverben
Jan 21, 2019 05:16 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CivicLX2001
Nov 16, 2001 06:33 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
