Tach install problems 2001 civic Please Help
Old Dec 30, 2007
ProjectMayhemR's Avatar
the best kind of lovin is from the oven!
ProjectMayhemR will become famous soon enough
Just installed a tach and tapped into a solid blue wire near the firewall. I believe this is the wrong wire. Can someone please tell me the right wire to tap into, the exact location of the wire, and which blue wire it is because there is like 3 or 4 in the same spot? Thanks
Old Dec 30, 2007
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Re: Tach install problems 2001 civic Please Help
There should be a tachometer test wire behind the passenger headlight, that's where most people I know have it spliced. It's blue with a white stripe.
I would also include the year of the car and if it's a coupe/sedan in the actual message. It took me a few seconds to see it in the title, others might completely over look it.
Old Dec 30, 2007
ok is it the blue wire with the little square plug?
Old Dec 30, 2007
Jza's Avatar
Jza
as far as I know, yes.
Make sure that the tach is powered and grounded correctly, as this kind of faulty wiring could also cause it to not work properly, if at all.
Old Dec 30, 2007
everything else is done correctly. My dad tested it.
Old Dec 30, 2007
Jza's Avatar
Jza
well you've tapped into my brain as much as you could, there are other methods of wiring a tach on an '01, but I know this is the easiest. The tach could be defective, but I'm sure someone else will post valuable information.
Again, blue white stripped wire near the passenger headlight with the weird plug at the end is the tach test wire, it should work so long as you have found suitable ground and a good power source.
Old Dec 30, 2007
well we r going to try the blue wire with the plug.
Old Dec 30, 2007
Jza's Avatar
Jza
oh, then it's definately that lol
Old Dec 30, 2007
it worked thanks man
Old Dec 30, 2007
Jza's Avatar
Jza
no problem
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
mattdoc
Mar 14, 2017 12:10 PM
lilbluecivic
Nov 7, 2001 06:49 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
