Coil Packs
Coil Packs
Will a '03 SI coil packs work in a '01 LX? Looks the same but not sure?
Could someone verify this.
My LX is misfiring, and I need to replace my packs but not sure which one is bad. I know there were 2 that was going bad but I am not sure how to figure out which one. My CEL was on couple of months ago and Autozone told me before but I just changed out the plugs and everything was good until now I can tell it's sluggish at times. Any help would be greatly appreciated.
TIA.
TIA.
Re: Coil Packs
try a cylinder power balance test
.. warm car to operating temp, then record rpm, pull fuel plug one by one, record each rpm drop. when there is one that doesn't drop in rpm when you pull it, that's the one that is broken.
Orrr... the easiest way is just to get an infrared thermometer and point it to each exhaust outlet . if its misfiring, then that outlet going to register lower temp.
Re: Coil Packs
I did what you suggested and they all dropped. I will have to take my fluke home from work tonight and take the temps and see if that helps.
I wonder if it's even the coils packs. When I was told it was, I went ahead and changed the plugs (I always use Bosh Plat2) but eversice then now I notice every so often in 2nd gear it tends to run sluggish at times almost feels like im on the wrong gear or something.
Any other thoughts? Oh by the way I have 215k on my '01.
Re: Coil Packs
um coil packs almost never go bad unless you threw it on the ground. if you want test the resistance of each one with a multimeter. you need to figure out which contacts to test, but you will get a reading that is not zero. then do it for them all and the values should be similar. if one is way different, its the bad one. but misfire is almost always caused by blown head gasket, or bad spark plugs/wrong plug type/improper plug torque or clogged fuel injectors.
Re: Coil Packs
Ouch... too much for me, I guess Im better of taking it in since I have lots of miles (215k) on it as it is.
Not sure how to even test or check everything you had mentioned above. Thanks for the info though. Maybe someone can PM me or post here where or how I should even start looking into this further.
Re: Coil Packs
well first replace the plugs with some simple ngk copper and see if it goes away. then can look at bigger issues. throw some techron concentrate in the gas tank. then worry about the coils but i have a feeling its not those.
Re: Coil Packs
have you been using lowest grade gas for all 215k miles? its very possible your in need of a good ol fule injector cleaning, or possibly one is going bad at the least. that is if the sparks are good...
Re: Coil Packs
have you ever thought trans issues? had you ever changed the clutch or even do an overhaul on the trans? is it only on 2nd gear or all gear has it but not as prevalent? i don't think its any prob with the engine if all cylinder is fine and firing correctly.
Re: Coil Packs
I just thought it would have something to do with the packs since my CEL was on and that's what they said it was back then. The only difference now is that it doesn't ran as rough eversince I did the Bosch Plat2.
Thanks again to you all for the suggestions.
Re: Coil Packs
the best fuel treatment is the FP60 plus from lubecontrol.com but it does take a month or so to fully clean everything out. its meant for constant use in every tank. you could try it out. but getting low octane gas is fine, you would have actually have alot more carbon deposits using higher octane that the engine wasnt meant to burn. but being that old i guess over time something got clogged up.
Re: Coil Packs
Re: Coil Packs
i dont like additives either, but ive been using their lc20 in oil and fp60 in gas for over two years without problem. the stuff has been tested to work, unlike stuff in the stores. fleets of trucks have been using it for over 40 yrs to save on gas and engine repairs. my car gets consistent 42mpg on the highway and runs better than new. i only have around 60k miles, but the engine feels very smooth still. oh and im using regular 87 gas and oil. these are not harsh cleaners, the oil additive mainly stabilizes and reduces oxidation, while gas treatment cleans the fuel system. its gentle enough that you prolly wont notice a difference until a few weeks later at least.
Re: Coil Packs
If I remember correctly are engines are really fussy and don't like the bosch spark plugs for some reason. Are engines only seem to run good on the spark plugs from the from honda (ie. denso). I have heard a lot of people having problems w/ the bosch plugs in our cars.
Re: Coil Packs
I had a coil pack go bad after an overheat and headgasket pop. They only had 30K on them. I don't know which one it was as I had an extra set and just swapped them out and was fine.
What about the tried and true Sea Foam?
Re: Coil Packs
sea foam? lol ive heard too many horror stories to ever recommend that. and idk, i blew my gasket a while back and coil packs were fine. maybe if you let the temp get into the red zone bad things might happen. just use ngk or denso plugs.
Re: Coil Packs
Yeah, I know you can really fug up a car if you do it improperly. As far as the overheat and coil pack pop, yeah it was July, my wife was driving, and it got very hot.
Re: Coil Packs
even if you do it properly, that stuff pretty much lifts off chunks of carbon and they have a party in the engine. the lc20 stuff dissolves the carbon and puts it into solution where it gets trapped in the filter gradually. gentle is key.
Re: Coil Packs
That seafoam stuff is snakeoil. Makes a big show, but doesn't do anything. There was a video on the web a while back where they had a before and after shots of the internals of a motor that got the seafoam treatment.
Try plugs and fuel injector cleaners. Those are cheap and easy to do. As others have stated, it's fairly rare to have coil packs go on a honda that is only 5-6 years old.
Hope that helps!
Hope that helps!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
