Disassembling Side Mirrors
Old May 22, 2007
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
How do you take apart the side mirrors, i want to replace the motor
Old May 22, 2007
burke420's Avatar
The World Is Yours!
Re: Disassembling Side Mirrors
well.. all i can tell you is to remove the plastic sail panel, then unclip the wire, remove bolts, and the mirror is off. then to remove or replace motor... ?
Old May 22, 2007
1sykcivic's Avatar
RHCP0801 is my hero
isnt the motor in the shell between the plastic and the actual mirror
Old May 22, 2007
i thought motor is in the mirror piece. take it off first then i think the glass carefully can be pried off to see inside.
Old May 23, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
To remove mirror assembly.
I believe the mirror is just glued to the actuator and can be pried off. I think you should probably take the mirror off first, but probably not necessary. My manual is in the car, I can scan the removal of the mirror if you need it.
Old May 23, 2007
1sykcivic's Avatar
RHCP0801 is my hero
ok i tried puttig it to the max setting and looking to see where its attached, looks like theres like 5-6 things connecting to the mirror? what do i do
Old May 24, 2007
bobsagator's Avatar
Mirror removal attached.
File Type: pdf
Old May 24, 2007
speedfoos's Avatar
^^^^Word. Its how I did mine.
Old May 24, 2007
ragingSPAM's Avatar
I just burnt my tongue
the glass just pops out cuz its clip in with some glue so its an easy replacement
Old May 24, 2007
speedfoos's Avatar
Just make sure you firmly re-attach them. Because otherwise - when you're racing around from stop sign to stop sign, smoking those unsuspecting grannies in their stock Oldsmobile Cutlass Cieras, hazards flashin', fart can a-blarin' - its shake, wobble wobble, shatter, as your mirror impacts with the pavement.
Old May 26, 2007
1sykcivic's Avatar
RHCP0801 is my hero
repped bob sagot
Old May 26, 2007
speedfoos's Avatar
LOL, yeah. I cried when one of my mirrors did that.
Old May 26, 2007
1sykcivic's Avatar
RHCP0801 is my hero
Erndog81
Oct 31, 2015 03:01 PM
671civicLX
Jul 9, 2015 03:22 PM
Dean Walker
Jul 7, 2015 02:27 PM
nongv
Jan 2, 2002 02:09 PM
