how much hp with n/a setup
Old Apr 23, 2007
BigD001's Avatar
BigD001 can only hope to improve
my friend wants to know how much hp do you think he could get out of this set up:
Forged Pistons
rods
port n polish
stage 2 cams with valve
header
intake
ehaust
test pipe
Apex VAFC II or hondata
pulleys
cam gear
flywheel
and tuned
and is it possible to bore it out to a 2.0l
Old Apr 23, 2007
andyman97's Avatar
Turbo Guru
Re: how much hp with n/a setup
This forum is for forced induction and swaps, moved to 7th gen engine.
I was actually thinking about a sleeve job and an overbore job. I don't know that 2 litres would be possible but I want to go as big as I can when I do it. He should go as high compression as possible for max power. Forget the AFC hack, hondata all the way. I would definitely run a stage III cam instead of II, I've spoken with tuners who've been very dissappointed with stage II even on turbo setups. Definitely should consider a good aftermarket intake manifold for max flow and some port work on the head. All and all, if he can get to 175 whp n/a, he's doing damned good.
Old Apr 23, 2007
electric130's Avatar
not sure with OBDII, but an engineer i work with has a 92 hatch, B18 bottom, B16 VTEC head, OBDI ECU that he's programmed himself and his last dyno was 185HP, all N/A. i've been talking to him a lot about it since i want to start a project car soon. if you want to stay N/A, OBDI is a lot easier to work with from what i understand. you just put a DB9 connector on the ECU and hook a laptop to it to program/tune it.
