Oil Gurus! Questions not answered regarding Synthetic oil.
Upon many failed searches on the forum, I have yet to find a good solid answer. Compared to the XXXX km/mile standard oil change interval, does using a full synthetic blend such as Mobil 1, increase the mileage that I can drive or is this just a myth? What is the PROPER recommended interval for Synthetic?
**I could have missed my answer to this in the search**
I just burnt my tongue
Re: Oil Gurus! Questions not answered regarding Synthetic oil.
well the fact is that synthetic oil's don't have any wax in them unlike petroleum based oil's...the higher mileage comes from the lack of wax build up in the engine from constant heating and cooling...i use mobil1 5w-20 full synthetic with a mobil1 "extended performance" oil filter and it works great...i still change my oil every 3000 miles because no matter what oil, synthetic or regular, still has its limitations and changing it in early intervals will keep your engine healthy...they say 5000 or 7000 because they formulated and tested it on "most cars" without seeing much engine damage when you go that mileage without a change...i still tell people 3000 because the average person wont change their oil for around 5000 miles so if you use synthetic it wont cause build ups or damage (not saying that regular will either)
Boobies are the mans tinkertoys
don't buy synthetic..........................only use petro oils (or my pockets will go dry
Adding on to what raginSPAM said, you can run 5000 - 7000 miles on any oil. Although its not recommended to, you can. Once you get above that on cheaper oils you will notice build up quicker than the better oils. I still change it every 3000 though with Penzoil 5w-20.
)Adding on to what raginSPAM said, you can run 5000 - 7000 miles on any oil. Although its not recommended to, you can. Once you get above that on cheaper oils you will notice build up quicker than the better oils. I still change it every 3000 though with Penzoil 5w-20.
Read:
http://neptune.spacebears.com/cars/s.../oil-life.html
http://neptune.spacebears.com/cars/stories/mobil1.html
I use 5W-30 Mobil 1 changed every 5k miles since it looks almost new when I drain it and I cut my changes in half from 3k miles with Dino. It is an Engineered oil and is the best in my books!
I think it is have to say you could go to 7k miles if on a tight budget or do a filter and top-off at 4k miles and run it to 7k miles to ease the budget. Great stuff!
RIPSAW
Nov 6, 2015 04:36 AM
amrhamed
Jun 1, 2015 08:08 AM
greencivic805
Nov 16, 2001 10:36 PM
