has anyone ever swapped this k series in there 7thgen???
...JeRsEy sTyLe...
http://www.osakajdmmotors.com/codes/hondaK20A.htm
just wondering if its worth it
the specs are the same as the a2 as far hp tq. and redline
trans is the same specs also and is 6speed.
comes with ecu..
hm i wonder if it would be worth it to use this? and what kinda vtec it has
is it the a2 or a3 ivtec?
id prob swap out the im for a a2 one or type r one.
comes with ecu..
...JeRsEy sTyLe...
Re: has anyone ever swapped this k series in there 7thgen???
lol you guy cant read.. obviously k series have been around
but this is the k20a base model motor.
the specs are exactly the same as the k20a2 here
K20A - EURO spec
• 147 kW (200 hp) @7400 rpm
• Torque 196 Nm @5900 rpm
• Redline 8100 RPMS
• Bore 87mm
• Stroke 86mm
• Comp Ratio 11,0:1
• Displacement 1998 cm3
• Specific output 100HP/L
K20A2 – US spec RSX type S motor
• 200 HP@7400 rpm
• Torque 142 lb/ft @ 6000 rpm
• Redline 8100 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 11.0:1
• Displacement 1998cc
Trans Specs
• 1st 3.267
• 2nd 2.13
• 3rd 1.54
• 4th 1.14
• 5th .92
• 6th .73
• Final Drive 4.388
K20A - EURO spec
• Redline 8100 RPMS
• Bore 87mm
• Stroke 86mm
• Comp Ratio 11,0:1
• 200 HP@7400 rpm
• Redline 8100 RPMS
• Bore 86mm
• Stroke 86mm
• Comp Ratio 11.0:1
Trans Specs
• 1st 3.267
• 2nd 2.13
• 3rd 1.54
• 4th 1.14
• 5th .92
• 6th .73
• Final Drive 4.388
...JeRsEy sTyLe...
haha i know ... but the motor has the same specs as the USDM k20A2 and 6 speed trans???????????????/ soo im trying to see how it is compared to the type S motor..
...JeRsEy sTyLe...
those motors are different one has a silver mani cover and the other is black.. there different i got the specs off of xproductionz website.
