Emanage Questions
Emanage Questions
This is just a quick check as to my understanding of how the emanage works, im not a tuner and i'm not trying to pretend to be one, I just want to understand whats going on in the car
. Thanks in advance for any replys.
I understand the idea behind 2 things - that is, retarding\forwarding the ignition timing (past or ahead of TDC), the injection map, which is basically adding to the pulse rate so the injectors stay open longer but what I dont understand is how to interrupt the correction factor with respect to the airflow adjustment map. I have 310 injectors and the correction factor is 220 - 310 which is .7, so if I set the Airflow Adjustment to 50, how much actual fuel is that asking for - 310?
Also, do you need the additional injector harness to use the sub-injector map? and what does the acceleration map do?
. Thanks in advance for any replys.I understand the idea behind 2 things - that is, retarding\forwarding the ignition timing (past or ahead of TDC), the injection map, which is basically adding to the pulse rate so the injectors stay open longer but what I dont understand is how to interrupt the correction factor with respect to the airflow adjustment map. I have 310 injectors and the correction factor is 220 - 310 which is .7, so if I set the Airflow Adjustment to 50, how much actual fuel is that asking for - 310?
im pretty emanage noob myself. about the 220-310 correction factor: why does it matter it jsut does it automatically so why care? lol and yes you do need the injector harness to access anything injector related on the emanage. and i have no idea was the acceleration map is.
do not take my word on any of this. cuz i really dont know myself.
i have my emanage in my car with no harness. so its basically just a blue box sitting in my car
i really need to get this thing up and running, im scared of my fmu.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
