aiming your after market projectors on 04 civic
hey, i'd installed these after market projecotrs on my 04 civic. & im wondering how to adjust the projectors because they seem to aim str8 ahead, and not on the street. plus i'd just installed 8000k HID'S so when im driving @ night, people always flash their high beams at me. can anyone help me out?
I just burnt my tongue
get a screwdriver and on the back of the headlight there will be a slot with a lil disc lookign thing with teeth in it and you can stick your screwdriver in there and twist to either get it up or down
well people will always flash you because hid in a halogen projector throws light everywhere. you can aim them down but really it wont matter much. maybe give you a bit more light but this is why you should just open up the headlights and swap in some hid projector lenses. will be a world of difference.
is there a way to tilt the thing from side to side? my right projector is pointing a little twisted. my headlights seem to aim something like...
but the right side is not so exagerated.. just slightly and it's bothering me
The problem is probably due to the installation. Did you put everylight in the housing??? Park light, blinker lights head lights ( obviously ) highbeam.
You should plug the inlet of the park lights even if you dont use them. It seals moisture from getting in.
I also noticed that splash shields AKA fenders liners are really important. They block the treading water to hit the head lights. In rainy days it will go straight into the head light housing.
i think it would be the park/blinker light that's not air tight then. how would i go about sealing that? the high/low beam has a plastic lid for the whole thing, but not the park/blinker
what do splash shields look like?
eBay Motors: SPLASH SHIELD honda CIVIC COUPE 01-03 front 02 part LH (item 330083329520 end time Feb-07-07 09:55:53 PST)
First you have to make sure the splash shield is on there properly or else all the water treading will hit your head lights and engine area.
Second you have to make sure the park lights are covered. Moisture usually enters through these little sockets areas where light bulbs go in. make sure it goes on there tight!
GaryFishell
Apr 24, 2015 06:49 PM
