need help taking off driver side door panel
Old Jul 7, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
How do I take off the driver side door panel? the rubber piece that goes around the window moved out of place and i need to take the whollle door panel off. I have already pulled out the parts with the clips but it hangs on im guessing a screw or two.
Old Jul 7, 2006
01civicdriver's Avatar
01civicdriver is an unknown quantity at this point
first you take out the little plastic piece in the door handle and take out the two screws. there is a metal rod that controls the handle and that needs to come off of the plastic clip its in. all you do is slide the clip and pull up. then you pry off the plastic piece under the controls there is a little slit in it for a small flat head to go into.
then there are two screws in that that you need to take off. then the little black piece in the upper right hand corner that covers teh bolts to the mirror needs to come off. then its just pulling off the panel and undo the wiring harness for the window controls. that should be it
Old Jul 8, 2006
vicLX's Avatar
<--That really is ME
pics or links ??
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
MamaBear2015
May 3, 2015 02:17 PM
ej8
Apr 13, 2015 06:36 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
