Cluster pinouts
http://www.7thgencivic.com/forums/sh...d.php?t=254507
The pinouts that you want are the ones labeled 2004 VP. Yes they are the same as a 2001 as the Civic Value Packages used the older style 7th gen clusters.
You're welcome
You're welcome
i asked gearbox and he doenst know the pinouts. and 01HonderCivic that only shows what color the wires are i need someting like this. heres an integra pinout chart;
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
i have the cluster apart and i have the wiring diagram but im not really good at reading those. while im on the subject does anyone know how to remove the needles without breaking them.
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
needles you can try and pull straight up using first three fingers and pushing against the cluster to get leverage. But sometimes they dont come out very easily. Another way is to carefully get thin scissors, and pretend like you're cutting it so that there is a blade on each side, then just try and pop it off.
i am trying to get ahold of an electrical manual but it wont be very soon. and also you need to know what the wires in your car mean too.
well its all blue led lighting except red needles. the wires are in completely different pins compared to 03, and I also wanna see if the IMA can be hooked up to show a graph of battery voltage or something. Its alot bluer than the pics show ha. I'm sure the BATT meter can be used as a voltmeter
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
badbaja
Sep 16, 2015 08:10 PM
rayman009
Sep 12, 2015 08:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
