Anyone put the lock in a carbon fiber trunk??
Old Mar 23, 2006
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
My g/f just got a cf trunk for her 01 coupe, and i see that the lock hole, is not pre drilled. Is there anything i should know about doing this, or any good hints to point me in the right direction?
Old Mar 24, 2006
05_ CivicJDM's Avatar
I thought they usually come with a pre-drilled hole... Someone else know this?
Old Mar 25, 2006
I actually just drilled it out. There was a problem though.
The lock is held in by two 10mm bolts on the back side. On the cf trunk, the hole that the lock goes through is too thick, so the lock can't even stick out of the hole, let alone be flush with it. So now i have to grind off some of the material where the lock will mount up. Also, none of the holes on the bottom side of the trunk lid are drilled, save for the two by the trunk latch. So it was, either run the wiring differently or cut out those oval holes so i can run the wiring like factory. Also had to drill out all the holes where the little clips pop. So before you put your trunk on, look at the old one, and drill all the holes out first.
Old Mar 25, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
what brand name trunk was this?
Old Mar 25, 2006
XxGoldCivicxX's Avatar
XxGoldCivicxX is an unknown quantity at this point
It's a VIS, i bought it through the group buy with showstoppers.
jordan1794
Jun 8, 2015 04:03 AM
nickeynick
Apr 27, 2015 01:23 PM
cperez53
Apr 16, 2015 09:31 PM
civicdown4u
Nov 27, 2001 12:05 PM
