Cluster removal - help please
Old Mar 19, 2006
civic_newbie's Avatar
civic_newbie is an unknown quantity at this point
Is there a trick to getting the black surround off? I know you remove the two screws at the top then yank...but the bottom just won't budge. Are there other screws or clips holding it down? I want to get to the cluster behind
Old Mar 19, 2006
dirtySAMURAI's Avatar
I log in from time to time
you have to pull it hard.
Old Mar 19, 2006
streetglower's Avatar
yup pull really hard, if i remember correctly, there is glue holding it down
Old Mar 19, 2006
sltuner88's Avatar
sltuner88 is just really nicesltuner88 is just really nicesltuner88 is just really nicesltuner88 is just really nice
search.........covered thousands of times....i even went lookin
Old Mar 19, 2006
rEkKaShInObI's Avatar
Unsalvageable
its flexible plastic, dont worry.
Old Mar 19, 2006
Thanks for all your help...finally got it off...had to get screwdriver to pop the two bottom clips
Old Mar 30, 2006
e04241's Avatar
e04241 is an unknown quantity at this point
thanks to this thread i was also able to remove the bezel. although im having a hard time switching wires... the wire wont come off of the connector
i've hear an "extraction tool" is needed but we dont have such here.
Old Mar 31, 2006
4rns860's Avatar
4rns860 is an unknown quantity at this point
you mean the wires that are connected to the sockets? or the socket plug from the cluster??
Old Apr 2, 2006
e04241's Avatar
i was able to detach the cluster from the main wiring harness(blue and green).
i cant remove the wires from the blue and green plug. how do you pull them out?
Old Apr 2, 2006
R1Style's Avatar
Don't just yank on the wires you'll strip them or rip/break them right off the connecter which will require you to solder them back on.
Get an extraction tool at a hobby store or you could use a small and long needle to push the tabs down and push them out.
Old Apr 2, 2006
haha i used pliars and yes a few of em stripped lol. make sure before doing anything that the two lock clips on each side are pried off.
Old Apr 4, 2006
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
there are little clips on the sides of the harness. You need to use a small screwdriver to pop this off, once you do, with a little force you can pull them out one at a time with your hands no tools needed.
fatih717171
Jul 25, 2016 06:22 PM
greenbackz
Jul 30, 2015 12:04 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
fatih717171
Jul 8, 2015 12:14 AM
