Need Help Automatic Shift Knob
Old Mar 19, 2006
oxweeblexo's Avatar
oxweeblexo is an unknown quantity at this point
Need Help Automatic Shift ****
allready looked high and low for this but didnt find it. i only read sucessfull changes. I changed my shift **** for my automatic 02 lx coupe but when i turn the key off and the car is in park i cant get the key out. i have to pull the **** up abit so that the key can be unlocked. is there a way to fix this? i went to the honda dealership and they told me that i needed to ground a wire but he didnt know which. did any one have this problem and how did you fix it? if not what shift **** do you have and it works perfectly fine.
Old Mar 21, 2006
Suzy Q's Avatar
2 cups sweety 8 cups bitch
Suzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond reputeSuzy Q has a reputation beyond repute
Question
i had the same problem for about 3 minutes, until i realized that when i screwed in the shift ****, i screwed it to far pushed down and it put my car in between gears.
you cant take the key out when the car is in gear. in this case your car was in park, as so was mine. but the car thinks you are about to change into a gear.
what kind of shift ****?
Old Mar 21, 2006
RHCP0801's Avatar
LMAO the dealer said you need to ground a wire, total bullshit. like ^ said you just put the **** on too low, just raise it up and you should be good, damn thats funny
Old Mar 21, 2006
tuner04civic's Avatar
spell check pwns you
you have it pushed down too much and its pushing on the tripper. raise it up a little and should work fine. i had same problem
Old Mar 21, 2006
a4turboss's Avatar
a4turboss has a spectacular aura abouta4turboss has a spectacular aura abouta4turboss has a spectacular aura about
ur dealership is a full of a bunch of morons u should go and bitch at them
Old Mar 22, 2006
oxweeblexo's Avatar
yea i bought a dojo shift ****. it was to short of a push down so i had to loosen the screw underneath to make it longer. it works fine now though and yea i did call the guy an idiot also thanks for your responses.
Old Mar 22, 2006
ramcosca's Avatar
Words on a User Title
Like 96% of stealerships. I mean dealerships, sorry.
Welcome to the forums, oxweeblexo.
dantheman42
Sep 4, 2015 01:10 PM
junkyardguy
Sep 2, 2015 06:07 PM
naokigoffi
Aug 30, 2015 06:19 PM
JetsterDajet
Aug 15, 2015 08:07 AM
