Question about Hondabond
Old Jan 27, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
First noted difference.... a tube of Hondabond from Acura is $19.XX
A tube from Honda is $13.XX
Note to self, don't buy parts from acura.
Anyways... the back of it says the surface layer sets in 60 minutes, sets to rubber-like in 15-16 hrs, and fully cures in 3 days. So, ummmm, does that mean don't drive the car for 3 days after dropping the oil pan? It gives the specs of 77F and 50% humidity and that its cured by reaction with atmospheric moisture.... so I take it a hair dryer would accelerate this? And does anyone know if the "atmospheric moisture reaction" is sped up my more or less humidity?
Old Jan 27, 2006
streetglower's Avatar
What I can tell you when I installed my new oil pan was first off honda bond is a messy *** sealant. it doesnt come out of the tube as nicley as I would have liked. I got **** everywhere. But I waited about an hour to 2 hours before I added oil to the pan after I installed it. and it worked out just fine. I had a small leak from where I didnt add enough hondabond, but sealed it up with some more.
The manaul says when putting it on the pan to install it within 4 minutes, otherwise you need to redo it. It also says to use 2 layers, each 4 MM beads. it also says you can add oil 30 minutes after installing it.
I am not sure about all the other stuff you asked, so I gave it to you in my explanation. Hope it helps.
Old Jan 27, 2006
djmota's Avatar
I would give it a couple of hours before adding oil. after that IMO its safe to run the car.
Old Jan 27, 2006
dj02's Avatar
a good 4-5 hour set is all it really needs.
Old Jan 27, 2006
you want to let that stuff set fully, even longer than recommended if you can.
Old Jan 27, 2006
diskreet's Avatar
not everyone has the luxury of taking a civic out for 3+ days. When it comes to civics, they usually aren't the "2nd" vehicle.
Old Jan 27, 2006
take the bus
Old Jan 27, 2006
Al Gore FTW's Avatar
jdmtytedoridori
rent an s2k
Old Jan 28, 2006
Jap-Euro Fusion
Originally Posted by gearbox
take the bus
Take the subway, but yes, its a potential option provided that whoever's place we do the install will let me leave it there for a week and I can resist the urge to fire it up.
Old Jan 28, 2006
pon55's Avatar
"most" of the epoxies and sealents I work with that give a temp and moisture level will not cure quicker at higher temps.
Normaly to get higher temps you lower the moisture level, so cure time say pretty much the same.
An engineer at one of the larger companies told me they put that (temp/humidity) on there so idiots don't use it below freezing or in the rain!
(thats what he said, not me)
Old Jan 28, 2006
Jap-Euro Fusion
well I know nothing dries when its 35, I'm not stupid, but some of them will cure faster with heat.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
