re-tinting rear window?
Old Jan 16, 2006
i wanna know if its possible for the tint people to take off existing tint and put new back on without ruining the defroster lines. I don't like how they cut around the brake light so I wanna remove the deck lid and have em do it again. its been almost 6 months since i had it done so its not a fresh tint job.
Old Jan 17, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
Yes it can be done, go to a good tint shop not a crappy one though.
Old Jan 17, 2006
Da1lyDr1ver's Avatar
yea, they just peal it off or spray some solution on the tint to dissolve it...
Old Jan 17, 2006
okay thanks. sucks i didn't take the deck off the first time.
Old Jan 17, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
It cost more for them to take off than to put on.
It is a real pain, nothing disolves it, you have to use steel wool or a razor blade. Getting the acutal tint off takes about 2 minutes, but getting the glue off it very hard. You cannot see it until you spray something on it. Steel wool really does not work that well. Windex is the best thing I have found to work, it is what shops use too. I tried strait amonia and vinegar with no luck. I think I might have tried something else too, cannot remember. I sprayed so much windex on and let it soak and then repeated the process, no luck. That stuff just turns to snot man, it is kinda gross. If you let windex soak on it for too long it will congeal back up again cause the windex evaporates.
edit: I used goof off, which only works a little better, if at all. I used it toward the end when there was only a little glue left.
I ruined my rear defroster, only like three inches across work, cause I just used a razor blade. BUT I did not scratch anything. I think using the steel wool would scratch up the glass, but it really was not working so...
You do not need to take rear deck out, i watched the guy do it he is my friends brother. I actually just went through this because of a ticket and they did not cut around rear brake light when they put it back on, but I wish they did LOL
the only reason I got pulled over was because that brake light was out and had been ever since I had been driving th ecar Doh! Rookie cop came out of nowhere and pointed the tint out to the senior officer, who could have cared less if that little bastard would have kept his trap shut.
Check out this site
http://www.tintdude.com/remove.html
It has a trick to use a plastic bag, but I am not sure if it used to get the tint or the adhesive. it also has to be sunny out, but It was not at all when I remeoved mine, dead of winter.
I think the cold may have actually helped me because the tint peeled right off the adhesive in one peice. He mentions two layers of actual tint, maybe he uses different stuff. IDK
The responses on the bottom of the page talk about tint that is different than what I have, the shop I got it from uses top of the line.
Also one guy talks about taking it off in minutes with a steamer, but IDK about that.
I would just leave it be man.
Old Jan 17, 2006
dalaw's Avatar
Bone Stock!
yeah it can be done, dunno how much they charge though, some tint shops in socal heavily advertises tint removal
Old Jan 17, 2006
disturbed24st's Avatar
disturbed24st is an unknown quantity at this point
The shop i go to uses steam to take it off.It works really well
Old Jan 17, 2006
jackburton's Avatar
I would still think that even with heat that stuff will turn to snot. I mean it is meant to be really really strong stuff.
Old Jan 17, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
I used to use oven cleaner, worked very well
Old Jan 17, 2006
wow so this is prolly a bad idea. i don't wanna lose radio and defroster lines.
Old Jan 18, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
yeah really not worth it
you could try tinting over it, but they'll be a noticeable difference
Old Jan 18, 2006
what about having them cut a small piece and put it on just for the brake light space or will it be obvious there is a cut around it.
Old Jan 18, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
they didn't run the tint in front of the brake light? mine was ran all the way down w/o taking the deck out?
Old Jan 18, 2006
they said they couldn't flatten it back there so they had to cut around it.
Old Jan 18, 2006
thats a bunch of bs a heat gun and some patience woulda taken care of it.
anyway, an experienced tinter might be able to cut and place a piece of tint there without it being to noticeable, but theirs no way to get it to blend in perfectly
Old Jan 18, 2006
shmik1's Avatar
I know they charge $20 to remove the tint on front windows (they gave me a flyer that says front window tint is illegal and its not their problem, etc etc, and it will cost $20 to remove it.)
so my guess is removal of the back won't cost much... maybe $30.. who knows. ask them if they guarantee thier work, and if you have a problem make them pay.
Circuit city ended up paying twin city over $200 because they didnt get all my controls plugged back in and my rear defrost, ac, and cruise control wasnt working.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
breanna_17
Jul 21, 2015 04:01 PM
ballmich
Jul 9, 2015 11:59 AM
