Engine Swap/O2 Sensor CEL
Old Oct 10, 2005
andyman97's Avatar
Turbo Guru
Ok, so I swapped my d17a1 out of my dx for a d17a2 and swapped out the engine wiring harness and ecu. So, Anyone that's done this swap probably knows that the o2 wiring for the secondary is on connector E, not connector A.
Connector E is not part of the engine harness, but it's inside the car (and on the ex, part of it must run out to the engine bay for the sensor. Anyways, I need to know where exactly all of the four wires on the sensor plug need to go.
Now, the heater wire and the signal wire go into pin E. The signal wire should go to the wire for the ignition signal. The heater wire connects into the heater wire pin, obviously.
That leaves two wires, a green/yellow and I can't remember what the color is of the other. Anybody got any insight on how this needs to be wired up exactly?
Old Oct 11, 2005
andyman97's Avatar
Turbo Guru
So nobody knows the answer to this?
Old Oct 13, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
andy, I thought I posted earlier but I guess I didnt actually post it. If you want I can copy all of the pinouts and wire harness diagrams for the a1 and a2 engines out of my Honda book if you dont have them.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
R3KogHyZe
21
Feb 3, 2016 09:23 PM
Fastfebur
Apr 26, 2015 11:57 PM
Blaster30
Apr 22, 2015 12:21 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
