why only 120
Old Feb 2, 2002
jonjon's Avatar
jonjon is an unknown quantity at this point
why only 120
is there any why to make this car go over 120mph with out changing the ecu
Old Feb 2, 2002
Grey's Avatar
DIY King
Nope, the ECU limits the speed of the car and the rpm's of the engine. Actually, I don't know if it does one, the other, or both? Anyone know for sure?
Old Feb 2, 2002
Bartkat's Avatar
The limiter must kick in on RPM because you can force it at lower speeds in lower grears, at least on my autpmatic EX. It cuts out right around redline no matter what gear.
Old Feb 2, 2002
Bartkat's Avatar
If the cars came with V or Z rated tires, then they wouldn't have the limitter. But why would the factory want to put high speed rated tires on a Civic? The most I have ever got out of mine was 124 MPH indicated and it wasn't cutting out yet. I don't think it will pull any more in top gear.
Old Feb 2, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
Ive gone over 120 [IMG]i/expressions/face-icon-small-confused.gif[/IMG] maybe you got a retarded 2k1 [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Feb 2, 2002
Bartkat's Avatar
I wonder how much these guys figure 127 HP can pull against the wind? My LT1 runs out 147. Gets there a lot quicker though.
Old Feb 2, 2002
Cross's Avatar
Cross is an unknown quantity at this point
I maxed out around 131...Maybe you need to change yer oil or go with the wind or use 93 octane?
Randy
Old Feb 3, 2002
mohawkboom's Avatar
High Octane fuel will make you un even slower.... Higher octane fuel is as exlosive as lower octane fuels... it is good for high compression engines because it will not detonate as easily with compression as low octane fuel... Butting in cheapo 86 Octane fuel will give you the most Power from our 2k1's.. Not enough compression for pre-detonation anyways.
CHeers
Mohawk
Old Feb 3, 2002
Bartkat's Avatar
I disagree. The EX engine compression ratio is 9.9 to 1. That is rather high in today's engines. Just how does that engine keep from knocking on regular gas? I believe it's partly due to the computer sensing knock conditions and retarding the timing.
"Higher octane fuel is as exlosive as lower octane fuels". If this is the case then why do I need to run at least 91 octane in my LT1?
Old Feb 3, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
why do you need to go faster than 120mph anyway?
Old Feb 3, 2002
Bartkat's Avatar
I've had times I had to go over 120 and quicly to keep some SOB from running up my tailpipe.
Old Feb 3, 2002
Toronto's Avatar
Toronto is an unknown quantity at this point
<< .... Higher octane fuel is as exlosive as lower octane fuels...
CHeers
Mohawk
I believe he meant "Higher octane fuel is <font color=white style="background-color: 3E3E3E;">NOT</font ft> as exlosive as lower octane fuels", which I agree.
Higher octane fuel has higher resistance towards spontaneous combustion so that un-controlled burning does not happen as easily on high compression / hot running engines.
High pressure and high temperature are the main cause of pre-ignition / detonate.
Old Feb 3, 2002
Bartkat's Avatar
It's all a matter of engine tune and at what point you are going to get "pre-ignition knodk" (minor detonation)
Anyone with experience with the earlier emission control cars and the early unleaded gasoline will know what I am talking about.
Old Feb 3, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
<< why do you need to go over 120mph anyway >>
, Agree, the only thing your going to do @ that speed is kill yourself or SOMEONE else.
Old Feb 3, 2002
Bartkat's Avatar
If you got some redneck in a monster 4x4 running on your back bumper and you speed up to 90 or so and can't get over on account of the right lane is full of traffic, then it's nice to be able to speed up and find a spot to get over. Besides, those 4c4's don't corner all that well at 120 so he'll probably back off. It's not that you want to go out and drive 120 all day, every day.
Old Feb 3, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
Why....do you race?
Old Feb 3, 2002
VTEC2001CIVIC's Avatar
VTEC2001CIVIC is an unknown quantity at this point
I think that last statement is bs. I don't mean to tick u off or anything, because i think that is the only reason you would speed up to 120mph. If the person in the truck ticks u off so much, I would slow down and pi$$ him off. I can see maybe having a higher rev limiter (If you had more power)to get out of his way when you're merging onto a highway, but not up to 120mph cause that doesn't make sense.
Old Feb 4, 2002
Belle's Avatar
Belle is an unknown quantity at this point
ok, i've gone 135 in my civic. there's no need to go much more than 80 to merge around traffic and such. when people creep up on your a$$, you just slow and let them get all mad. this one lady earlier wouldn't get off me, so i slowed almost to a stop. she floored it past me. i floored it as well and clicked on the high beams and followed her all the way to her exit ramp. never went faster than 100 though.
Old Feb 4, 2002
Bartkat's Avatar
Mebbe you jest ain't never drove around this neck of the woods.
Old Feb 4, 2002
NeoMagus's Avatar
my compression is 10.4 and I need 91+ in my Si, she has no problem doing 130+!
As for the 2k1, its not worth even going over a 100. After going past 100 it accelerates so slow to make it even worth it.
Old Feb 7, 2002
strokelessone's Avatar
strokelessone is an unknown quantity at this point
<< I maxed out around 131...Maybe you need to change yer oil or go with the wind or use 93 octane?
Randy
Or try a nice coat of wax, or kick all the fat bit@hes out of your ride
Old Feb 7, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
I've gone 121 with room to spare. Why does the manuel say to use 87 gas if your not suppose to?? And my car goes 100 kinda easily in 4th.
Old Feb 7, 2002
Bartkat's Avatar
Who said that?
Old Feb 8, 2002
Diznavis's Avatar
<< I've gone 121 with room to spare. Why does the manuel say to use 87 gas if your not suppose to?? And my car goes 100 kinda easily in 4th. >>
you are supposed to use 87. if you use any higher, not only are you WASTING YOUR MONEY, you are also LOWERING GAS MILEAGE
Old Feb 8, 2002
Bartkat's Avatar
I don't quite understand how using higher octane gas lowers mileage.
Old Feb 8, 2002
Ichiban's Avatar
So why are people telling other people to use a higher octane. And I thought all honda top out at redline at the top gear...unless this speed limiter is something new to hondas. i have gotten my moms 96 civic dx up to like 115 but then the car gets all unstable and stuff its kinda scary.
Old Feb 8, 2002
LOWBOY's Avatar
The only thing a higher octane gas does is burn quicker and better for more efficiency. But with our engines being ULEV, we dont need it. 91 or better octane is designed to be put in bigger vehicle with Eight cylinder and some 6 cylinder engines in them.
Old Feb 9, 2002
new2civics's Avatar
new2civics is an unknown quantity at this point
I would think 91 and higher would be better. Can anyone prove that Higher Octane is a waste of money
Old Feb 9, 2002
darelldd's Avatar
darelldd is an unknown quantity at this point
Burning higher octane gas in an engine designed for regular is a waste of money and a waste of the environment. Higher octane fuel burns SLOWER on purpose, and has fewer calories/gallon (thus you may see lower gas mileage). But lower gas mileage is negligeable. You'd never really be able to quantify it in real life. Higher octane gas wastes the environment because burning the additives that increase the octane number are nastier for the environment than not burning them. They're better than lead, but they still ain't great. If the engine is designed to run on regular, it will not benefit from fuel with higher octane. Among MANY other reasons for this - If it would increase the HP rating, or gas mileage, or whatever, Honda would simply specify higher octane fuel, like they do in many Acura models. It is no sweat off their brow, nor money out of THEIR wallet to spec it.
I won't sit here and prove these facts - they are well established, and can be found all over the internet if you want research them. Don't believe all the gasoline marketing hype. Knowledge is good.
Regards,
Darell
Old Feb 9, 2002
ModNewbieHELPME's Avatar
ModNewbieHELPME is an unknown quantity at this point
I read an article once about gas and different octane levels...to sum it all up the difference when burning them in a normal car, no forced induction at all, is that it doesn't matter what you burn....
burning the "cheap" stuff or the high octane stuff doesn't make a difference. unless your running a turbo or super charger.
