D17 Crank Bolt
Old May 15, 2005
classact307's Avatar
classact307 is an unknown quantity at this point
Exclamation D17 Crank Bolt
Help me please... I've tried everything. How does the bolt come off?
Old May 15, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
am i seeing double?
Old May 15, 2005
Rufus's Avatar
no doubt double poster!
Old May 15, 2005
streetglower's Avatar
you need to use a crank pulley holding tool while removing the bolt, otherwise the pulley will just turn with the bolt and never come off. You can get it at www.etoolcart.com here is the exact link to the tool
http://www.etoolcart.com/index.asp?P...ROD&ProdID=629
preferebly use a impact wrench to take the bolt off or try hard with a wrench, that bolt is on there at over 200 ft. lbs of torque.
Old May 15, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
hold flywheel/flexplate with pry bar/screwdriver, then use an impact gun to take it out. to access ring gear on flywheel/flexplate, remove starter. good luck
Old May 15, 2005
to acess the flywheel, you need to remove the tranny, or pull it aside. And to get the crank bolt off you dont need to remove anything. I am not sure what you are trying to remove.
Old May 15, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Have a friend sit in the car and put the car in 4th gear and press firmly on the brake... You still won't get it off though, need powerful air tools.
Old May 15, 2005
I hope you arent being serious?
Old May 15, 2005
Blahman240's Avatar
How so do you mean? About not getting it off? Or having a friend do that?
Getting it off with just a normal rachet isn't easy.
And even unortho tells in their instructions to use the method I said.
Old May 15, 2005
I am talking about having someone put the car in 4th gear while having there foot on the brake. That is the stupidest thing I have ever heard. And dangerous. And yes you can get it off with a normal ratchet, it will be very hard, but possible. But yes, a impact wrench will work best.
Old May 15, 2005
Blahman240's Avatar
How is it stupid! Its what gets the job done! Your an idiot if you think its stupid... aparently you've never done it. How is it dangerous? Its recommended by many companys also.
Old May 16, 2005
think about it, have someone go under there to remove a pulley while the engine is running, that is stupid. that is like someone changing there oil with the car jacked up on scissor jacks. It is dangerous and stupid to be trying to remove things with the car running. Why do you think manufactures always recommend removing the negative from the battery when working on the car? So it doesnt accidentally start. People are killed everyday because they try to take shortcuts when working on there car. they do it so they can bypass time, not reliazing the penalties of doing it. You may get by with doing it, but it would be more logical and smart to by the proper part to hold the crank pulley and remove it with a wrench or impact. Yes it can be removed with a ratchet, it depends on how strong you are. It would be easier with a impact, but not everyone has air tools at there house.
I dont know of any companies who recommend having the car run to try and remove a pulley. Please show me one company who recommends that.
Old May 16, 2005
ctv's Avatar
ctv
ctv is an unknown quantity at this point
No One mentioned have the car running!!!!!
putting the car in gear while the car is off, helps hold the crank implace aswell as someone holding the brake also prevents the wheels from rotating, thus the axles will not turn, THUS holding the trans from rotating, while ingear holding the CRANK!!!!!!
Old May 16, 2005
Blahman240's Avatar
Yea... Who said the car had to be running... If the car was running the pulley would be spinning and cut off some fingers.
And you disconnect the battery terminal so you can't short anything out...
Old May 17, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I needed a 3/4 drive impact to get mine off, running 1/2 inch hose@200 psi. It wouldnt come off with a 2 stage craftsman compressor with a 1/2 impact so I had my buddy bring his trailer over, like a big *** one. Mine was an 02. dont put them back on that tight cause you dont wanna risk tearing the threads.
Old May 18, 2005
streetglower, you can access the flywheel by taking out the starter. you of all people should know that. you dont have to pull out the tranny. getting the crankshaft holder would be the easiest way to do this project, but if he doesnt want to spend money, then my plan would be best.
WaryDriver
Aug 16, 2015 11:22 AM
jnissen
Aug 9, 2015 05:34 PM
WaryDriver
Aug 8, 2015 05:08 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
