Problem with side skirts
Old Apr 5, 2005
crlazer2's Avatar
crlazer2 is an unknown quantity at this point
hey, i have been having problems with my side skirts. They are made of polyurethane and are now falling off. Has anyone had a problem like this? I am hopping to find sugestions to try and fix them so i dont have this problem again. any help would be great
Old Apr 5, 2005
hustlelikem0fo's Avatar
what side skirts are they?
Old Apr 5, 2005
crlazer2's Avatar
they are by purestyling opium skirts
Old Apr 5, 2005
import2nr's Avatar
awd pwnz j00
I'd check all the sticky tape, maybe its losing its stickyness. Maybe the temp change made them change shape? I don't know, my side skirts are fine.
Old Apr 5, 2005
crlazer2's Avatar
I have noticed that temp change do effect these. I have noticed they shrink in the cold and become verry flexible in hot weather. The double side tape is falling off but i have tried to replace it with stronger tape. still no good. Can these type of skirts be atached my adhesive?
Old Apr 5, 2005
import2nr's Avatar
awd pwnz j00
Not sure. Go get what honda uses to affix their side skirts.
Old Apr 5, 2005
crlazer2's Avatar
I have asked people at honda maitnace and they just tell me to get rid of them
Old Apr 5, 2005
import2nr's Avatar
awd pwnz j00
LoL, figures. They put mine back on when some one tried to steal them off my car while it there getting work done, and the tape they used was awesome. I'd just look into a different tape...
Old Apr 5, 2005
crlazer2's Avatar
i think one of the problem is that the edge under the door is too small to hold the tape because they end up lifting and getting caught on my doors.
Old Apr 5, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
use some screwd in the wheel well part, or under the side skirt, forget the tape...or if you're good with ur hands, ur body filler ^_^
Old Apr 5, 2005
import2nr's Avatar
awd pwnz j00
Hmm, I didn't have that problem with my G5 skirts.. I would sand down the part that catches the door or something. Not real sure.
Old Apr 5, 2005
crlazer2's Avatar
i have screws in the wheel wells but the rest is held on by tape. im not sure if body filler will stick to polyurethane or help the door situation?
Old Apr 5, 2005
Pharoh's Avatar
Bobaganoosh!
I never had that problem with my G5's either...I had tape and tap screws
Old Apr 5, 2005
crlazer2's Avatar
i just want to find some way to be able to get in my car without getting stuck in lol
Old Apr 5, 2005
import2nr's Avatar
awd pwnz j00
well, be advised one day youre prolly gona want to take them off, so dont do anything permanent..
Old Apr 5, 2005
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
You can try to use Epoxy to glue them down.
Old Apr 5, 2005
crlazer2's Avatar
im wondering if 5200 marine adhesive would work well on them, but i do know if i use that then they will never be able to come off
Old Apr 5, 2005
crlazer2's Avatar
does anyone know how to hold them in place with pressure so that a good bond occurs
Old Apr 5, 2005
_Viper_'s Avatar
OEM rules all lolll
Old Apr 6, 2005
you should get brackers to help support the side skrits fron under. also, when the body shop put my side skirts on they used some type of solution on the tape that made it stick extra strong.... 2 years not with the kit and no problems.
Old Apr 6, 2005
blouisgod's Avatar
Life Begins > 6800rpms
a body shop will have some body glue that you can buy. i need to get some to affix my kaminari sides.
Old Apr 6, 2005
Darkwing_Dan's Avatar
Darkwing_Dan is an unknown quantity at this point
i had the same problem before. just remove the whole skirt and apply a new strip of double sided tape to 'help' hold it in place. now get some urethane glue from a paint/body place and use small amounts of it on the places that are giving you a hard time keeping in place. the glue can come off with relative ease in the future. i did my skirts like this and i have had no problems since. it really works great!
Old Apr 6, 2005
jepetto's Avatar
jepetto is an unknown quantity at this point
Mine kept falling off too until i got the super strong red double stick tape from home depot made for holding stuff on exteriors of house. No problems since.
Old Apr 6, 2005
crlazer2's Avatar
does anyone have a good idea on how to apply pressure to the areas that have tape behind them. Im thinking the more pressure applied when installing the side skirts back on would help the tape to adhere better? But i cant find a way to do this without damage to the body occuring. I also noticed this morning that the bottom of my doors have had the paint rubed off of them becuase of the edge of the side skirt keeps grabbing the bottom of the door
Old Apr 6, 2005
Stylingcivic's Avatar
Stylingcivic is an unknown quantity at this point
The stuff the body shop put on your tape to make it perminant is called Activator. My buddy gave sum when he painted my kit but I didn't put it on.
only car+kit+winter=oh crap
I' am also having trouble with my doors rubbing my side skirts.
Old Apr 6, 2005
crlazer2's Avatar
how long have you had your side skirts mounted to your car
Old Apr 6, 2005
crlazer2's Avatar
i have had mine on for jsut about a year and only had this problem once the winter kicked in
Old Apr 6, 2005
Nasdurus's Avatar
Nasdurus is an unknown quantity at this point
Best thing for everyone to do that has this problem is remove the tape completely off of the car then the skirt. Clean BOTH surfaces very well, wipe dry then use FUSOR double sided tape; Comes in a white box, works great. Want something more permanant, use Duramix Super fast panal adhesive.
Old Apr 6, 2005
crlazer2's Avatar
where can you purchase duramix super fast panel adhesive? how much does it usually go for
Old Apr 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
After 2 years im just now starting to see a very small part near the wheel well that is starting to lift. Ill prolly have to take them off and re-sticky them
