small dome light
Old Dec 9, 2004
bhc786's Avatar
bhc786 is an unknown quantity at this point
small dome light
I recently changed my headlight bulbs to the xenon ones and also want to do the same with the small dome light thats located between to blinker and the main headlight.... When trying to switch it there is no way i could be able to do that, and i was wondering to switch the small bulbs do i have to take the whole headlight out... b/c that seems like a lot of work to switch a bulb because on the DIY section i saw that to take the head lamp out you have to take off the bumper cover and stuff....
Old Dec 9, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
no, just remove the plastic tabs in your fender well, and then you have access to change your 194 bulbs
Injen
Old Dec 9, 2004
cordeez's Avatar
Member
cordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trusted
should work
Old Dec 9, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
yeh just take the thing off...
Old Dec 9, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
my mechanic managed to get it off w/o removing the fender.
I just took the bulb out and left the holder in there. Civic looks better without that nipple.
Old Dec 9, 2004
dalaw's Avatar
Bone Stock!
read the manual dude, unscrew the plugs under the fender and rip out the black plastic, you can reach your bulb from there.
Lopes101
Jun 7, 2015 08:04 PM
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
