Auto oil change
Old Sep 22, 2004
CivicS's Avatar
CivicS is an unknown quantity at this point
Auto oil change
any DIY for Automatic Transmission oil change? what i needed to watch out for? I'm planning to do it on my next oil change with Mobil 1 5w30 and Honda Auto Trans. oil.
thanks,
Old Sep 22, 2004
jawn_myek's Avatar
jawn_myek is an unknown quantity at this point
thats what i use..the with with blue...that says.."newer vehicle formula" i believe?
Old Sep 22, 2004
Use honda auto trans fluid only.
Old Sep 23, 2004
CivicS's Avatar
so all i needs is unscrew the bolt then let it auto fluid to drain out...right? also how many bottle of honda auto trans. fluid i needed to put on my car
i hope my car run smoother after all these new oils changes
thanks,
Old Sep 23, 2004
Tranny will feel alot better. It's good to change every 15k, since you're not draining all of it. There is still fluid in the gears and other lines. Our tranny is very delicate.
When I did mine, it took about 3 quarts. Get an extra just in case. When you measure the final fluid level, it should be near the top full line on the stick AFTER the car is warmed up and running.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
docmartin14
Jul 30, 2015 11:26 AM
beachglass
May 22, 2015 09:59 PM
BootyDo
May 7, 2015 04:46 PM
