AWD '01 civic
Old Apr 1, 2004
yellowcoppy95's Avatar
yellowcoppy95 is an unknown quantity at this point
Talking AWD '01 civic
i have a few things to mention before i even go into what it is that i want to do. first: i know htat this project is very labor intensive, expensive and all in all just a pain in the @$$ to do but the benifits, by a long shot, out weight the cons so here goes nothing. i want to turn my 2wd civic into an AWD monster. i lknow that this can be done i think but the main part of my question is this: if i can do this what parts would i need from my donor crv (besides the obvoius) and what is the price range that i am looking at. my next question is that what are some of the little things that i might overlook while doing this and what are the electrical and differential problems that i might have with this project. and third of all: is there anything else that i cant think of that maybe you can to help me with this because i know that this project is very doable but i just need a little help so anything that y'all can think of that would be even the slightest bit of help would be greatly appreciated thanx
Old Apr 1, 2004
Spider883's Avatar
9K Redline Owns U
the major problem will be the floor pan to fit in the drive axel and the trunk pan to fit in the diff. .. new rear susp from the crv and in the front also.. is the crv strut front? it not it might be even harder... cost.. crv parts 4-5k for engine, susp. and drive train, new floor and trunk pan 2-3k most likely, labor to intall and work out misc problems 2-3k plus
Old Apr 1, 2004
cryption's Avatar
2003 Nissan Frontier
if you have a doner CRV its much easier ...an awesome project
Old Apr 1, 2004
abmerop18's Avatar
Jam out with your clam out.
the F/R weight ratio is around 70/30, if not worse. you would be lucky to get about 20% or so of the power tot he rear wheels.
Old Apr 1, 2004
robbclark1's Avatar
Retired suspension supermod.
not if can fit the CRV engine into the civ, which should be possible.
Old Apr 1, 2004
robbclark1's Avatar
You can also see if you can find an AWD civic abroad that is totalled and take that.
Old Apr 1, 2004
MadWheel's Avatar
Premium Boosted Member
I tried to get the stuff together and brought this up before. Problem is, I want big power to actually take advantage of the setup. The RWD axels from honda simply don't hold enough power without breaking. If you had custom made axels then you could do it, but that didn't leave me with enough cash for my turbo.
They have awd 7thgens in Japan. Hydraulic operated though. Look into that.
Old Apr 1, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Its actually 61/39 and it'll move towards 50/50 if you plop a drive shaft, and a rear diff, drive axles and stuff back there.
Old Apr 1, 2004
024drlx's Avatar
024drlx is an unknown quantity at this point
interesting topice like to read more....
Old Apr 1, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
get some1 to buy you a civic ferio mechanics book (those thick *** books) and find the parts you need, and order them from hondawerx. Greg said he could get the parts, but just needed to know exactly WHICH parts. Hongkong has the ferio also, dunno if its the 4wd one though
Old Apr 1, 2004
PunkingCivic's Avatar
I need TP for my bunghole
might not be exact to our car but I found this on line
http://www.honda.co.jp/.../CIVIC/ 19.../cv87-022.html
www.honda.idv.tw/tech/0212/0212.htm
www.honda.co.jp/.../2003/ 5-manichi/kenin.html
Old Apr 1, 2004
robbclark1's Avatar
if that is for our car, that is a WAY different suspension/chassis, which makes me think that is an older ferio.
Old Apr 1, 2004
§C§H§O§C§O§B§O
yah...that don't look like the mcpherson (spell?) assembly up front
Old Apr 1, 2004
skjinx's Avatar
skjinx is an unknown quantity at this point
That definately looks like the Civic Ferio layout.
Old Apr 1, 2004
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
That's be an awesome project, like the one in my sig. The VTM-4 system from the MDX would be even better.
Old Apr 1, 2004
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
since the current ferio comes in awd. im sure you could import a service manual or something to see the details of the car and the parts you need. from thep pics, theres no flat rear floor for the awd.
http://www.honda.co.jp/auto-lineup/c...ype/index.html
Old Apr 2, 2004
first of all let me say thanx to everybody for their input and for not being rude about it cause in all truth and honest i thought that y'all were all gonna laugh at me for having a stupid idea but now that i know that it is possible im gonna start saving up my money any way i possibly can so look for more on this project in the near future and oh btw, is there anybody out there that knows of a way to make a cheap @$$ turbo kit or where i can buy one? thanx for the info everyone!!!!!!!!!
Old Apr 2, 2004
Master's Avatar
Banned by Admin
it would an awesome project, but you would want more power to be able to power the rear wheels as well, so I would save up for a turbo or k20 swap, then save up again for the awd conversion.
Old Apr 2, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well i can see a few problems u will be having...
there is a crossmember in between the 2 main chasis frames
and the fuel tank needs to be moved or modified to allow for the driveshaft
Old Apr 2, 2004
§C§H§O§C§O§B§O
^^^ can't that crossmember be cut off somehow? isn't it just there for support and rigidity?
Old Apr 3, 2004
the_duke's Avatar
the_duke is an unknown quantity at this point
Not to be a ****, but...
if you need to ask what parts you need, your not going to be able to do this. This is something that if you know everything there is to know about cars, you still learn as you go.
Old Apr 3, 2004
manu's Avatar
manu is an unknown quantity at this point
in japan they got a 7th gen awd civic ???? damn SOB's.
Are they using the D17A2 also or do they have another engine with more torque and HP ?
Old Apr 3, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
i think they are using the k20 with 160hp...
Old Apr 3, 2004
playaz0429's Avatar
playaz0429 is an unknown quantity at this point
good luck!
Old Apr 3, 2004
dragoon's Avatar
it's definitely doable, but then again, anything's doable with the right funds.
be prepared to spend, spend, spend!
Old Apr 3, 2004
zachgeyer's Avatar
that would be sick
Old Apr 3, 2004
MadWheel's Avatar
It's still the same D17, but it's also a four door, and really weak... The systems is only for driveability, the hydralic system they use will NEVER hold up to any FI civic.
Old Apr 4, 2004
mrchowmein's Avatar
same d17 like madwheel said, but they also have it in a non-vtec 1.5L version. guessing d15?
Old Apr 6, 2004
i really do appreciate every one's input on this project o' mine. and in reply to the_duke: i know and fully accept the idea that i do not know everything there is to know about cars. but thats the point; i want to keep learning about them until the day i can no longer pick up a tool to work on them; because if you know everything from the start, then it is pointless to continue because you already know everything! but anyways i also realize that this is not going to be a cheap and easy project to do, but in my eyes it is well worth any amount money, time and any other cost that come along with it. so thanx again and if y'all find out any more info, let me know!
Old Apr 6, 2004
cryption's Avatar
just hope you have a big wallet man
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
