Article on oil -- frequent change is bad??
Old Dec 13, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Article
Old Dec 13, 2003
Engineman's Avatar
T.V. is bad for you. Go outside.
Engineman is an unknown quantity at this point
Pretty much right. I don't change my oil until it starts getting real black and begins to have a smell to it. That is usually about every 5-6 K miles. I see nothing wrong with topping one off and spinning a new filter on. I have worked as a mechanic for awile now and seen
something truly amazing. There is a delivery man who rides a 250 nighthawk (motorcycle) and put over 100K on it in a little over 4 years. And guess what when he comes into the shop we just top off the oil. What kills me is the bike dosen't even have an oil filter. To the nonmechinical this seems impossible but it happens everyday. Just remember lack of oil and dirt is what trashes most engines. Anything else is just operator error or a warranty issue.
Old Dec 13, 2003
MangoEX's Avatar
Just Be
Then why do manufacturers suggest otherwise?
Old Dec 13, 2003
Engineman's Avatar
To sell you oil, filters, and service.
Old Dec 13, 2003
maxsin's Avatar
No Title
maxsin is an unknown quantity at this point
I just paid $23 for full sythetic castrol. That oil is lastin till 5000.
Old Dec 13, 2003
Engineman's Avatar
I run synthetic oil in all my cars except my bikes (cause of the wet clutch). Good stuff IMO.
Old Dec 13, 2003
solar's Avatar
solar is an unknown quantity at this point
Thats total BULLSHIT!!! the reason you change the oil isn't just for engine wear protection you change it because oil becomes contaminated. You could let your car go 15,000 miles because the oil still holds its viscosity, but the oil is fouled with all sorts of contamination, thats why old oil turns a dark color.
Plus that article was based on Mobil 1 synthetic oil, not regular "dino" oil. Its your car, so do what you want but, I have a 1989 Ford E-150 Van in my garage that has close to 250,000 miles on the stock original engine. I changed the oil on that Van every 3,000 miles since I bought it new. The engine still runs great and is quiet and doesn't burn oil, and I drive it very hard. So I think that says something about regular oil changes.
Old Dec 13, 2003
SMX's Avatar
SMX
SMX is on a distinguished road
You also change it because the additive packages break down and stop protecting your internals.
Old Dec 13, 2003
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
I'm curious to see the AMSOIL results when they are done. Probably similar. And, the point of the experiment was to see just how long the oil would last, not to recommend oil changes at 17k or whatever it was. I'll keep changing my Mobil 1 every 5k or so like usual, but good read.
Old Dec 13, 2003
MangoEX's Avatar
Just Be
So synthetic=dont change frequently, conventional=change frequently?
Old Dec 13, 2003
Engineman's Avatar
More or less. Just keep an eye on you oil color and smell. The darker color along with a gas like burnt smell is a indicator it is time to change the oil.
Old Dec 13, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Mobil 1, any synthetic for that matter will last longer.
1. its not carbon based, so it won't break down under heat very fast.
2. Some chemical nerd sat in a lab with the specific purpose of making it last and protect at the same time.
3. Synthetic is designed to hold dirt and contaminants in suspension, not let them settle on the engine parts.
6-8000 mile changes on Synthetic are perfectly fine. Mercedes recommends 7500 mile changes, BMW recommends 12K (which I don't believe, but say what they like), and most people now are saying every 5K for conventional crap.
Hell, Semi trucks change it every 60K... Go look into Delvac 1 (Mobil's HD synthetic)... you can go an easy 20K on that **** in your car with no problem (you'll probably have to swap a filter at some point, but the oil will still be good).
Old Dec 13, 2003
INCivic's Avatar
INCivic is an unknown quantity at this point
when is a good time to switch to synthetic?
Old Dec 13, 2003
deciuss's Avatar
Boosted Auto
i actualy just payed 53 bucks to have my oil changed today i always use mobil one. i get it changed every 6 months thow due to i never make it to 6,000 miles. Infact this time it was 6 months and i put less then 2,500 miles on my car
Old Dec 13, 2003
Jap-Euro Fusion
Mixed opinions on this. Leave the original oil in for 5000 miles. The assembly lube has high molybendium content, which helps the engine break in and seal up well. Since it gets run up in the oil, leave the oil. At 5K you can switch to synthetic or run another dose of dynojuice through it. The 2nd change (3rd batch of oil) you can go to synthetic between 8 and 10K. Once you go synthetic, don't go back.... synthetic flushes the carbon out, and reconditions the engine. Putting carbon based oil back in messes things up.
Old Dec 13, 2003
MangoEX's Avatar
Just Be
I also heard, on a new car, its best to change the oil within 1,000 miles due to the unsettled tolerances & rubbing/scraping of internals causing metal shavings to be let loose in the oil. No?
Old Dec 13, 2003
fine02civicgurl's Avatar
*BoY*CaR* *GiRL*DRivER*
fine02civicgurl is an unknown quantity at this point
i get it done every 10000.... like the manual says
Old Dec 13, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
wtf you payed $53 dollars to have your oil changed???? where did you get it changed "RIP YOU OFF OIL" dude you really should change it yourself it cost me $25 dollars for four bottles of mobil 1 super syn with a Fram Oil filter.
Old Dec 13, 2003
Novaz3's Avatar
and keep changing your oil every 10000 like the manual says and you wont have your car running as well down the long run.
Old Dec 13, 2003
deciuss's Avatar
Boosted Auto
many reasons.
1. im in college so i dont have time to do it.
2. i dont have a jack or jack stands at my house or my dorm
3. if i did have them at my dorm i cant just change it in the parking lot.
4. im fat 300pounds even with a crawler to get under the car when its jacked up and on stands i dont fit.
5. i also hate doing it i help change my friends oil all the time and the only reason is its something to do when its warm out.
so for me 53 bucks every 6 months is worth it
i have more reasons why i dont if you would like them
Old Dec 15, 2003
i trust honda's instructions on oil more than i trust civic guru's on a website
Old Dec 15, 2003
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
i hear ya on that ! i change mine about 5 grand or so
Old Dec 15, 2003
armieo's Avatar
< My future wife.
So if I put synthetic in at around 13k miles and then had the dealer do a checkup on my car at 18k miles and at that time they put normal oil back in.... what happens?
Old Dec 15, 2003
cdmx's Avatar
You know they are only saying your just wasting your money changing oil every 3k miles....well so what...ill continue to waste my money.
But in reality i forget to buy oil(i order online) and i end up changing oil every 4-5k
Old Dec 15, 2003
cdmx's Avatar
I actually checked my oil and it still looks pretty purple clean to me...(slightly dirty)
Old Dec 16, 2003
Green Civic's Avatar
I change mine every 3k miles. Only because the oil is very dark. I have done that with all of my parents cars, so it's a habit now.
Old Dec 16, 2003
AR's Avatar
AR
e-married to daydreamer
semi's run into the millions of miles though.
the life of semi can have over 2 millions miles on it i am sure. I have heard this time and time before. Semi's are FAR different from suv's and regular cars.
Old Dec 16, 2003
AR's Avatar
AR
and i change my oil every 3k. i wouldn't have it any other way imo.
Old Dec 16, 2003
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
I change my oil every 3kbecause I like to run my car hard I change it every so often so it stays running good, if you drive your car a lot you should change it every 3k but if you hardly drive and use your car to work and home and going to eat then I would suggest 5k!
Old Dec 17, 2003
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
The oil you buy today is far better than what was available 5-10 years ago. You really don't need to change it every 3k.
Iffy Lube wants to pound it in your noggin that it's every 3k or your car will die. It's a big marketing gimmick. Hooey. Just anothe way to have you part with some of your hard earned money.
Years ago 3k was a good idea because oil didn't have the same additive/detergent packages it does now and filter technology wasn't nearly as good as it is now.
You can take advantage of this new technology, at no cost to you, by simply letting the technology work! That means leaving it in for 5k!
If the oil is black that means it is doing what all the high tech ingredients are supposed to do - hold all the bad stuff in suspension. If it wasn't dark then you should be worried.
A high quality oil will go 5k and there will be no loss of protection. You can spend your money on oil every 3k and waste it thinking that you're doing your engine some greater good that really can't be measured or you can spend the money on beer and pizza.
This really isn't about consuming calories; it's about making good maintenance decisions about your car. Using the "more frequently is better" line of reasoning, you could change it every 100 miles but that's sounds kinda dumb, doesn't it? The same reasons that 100 mile changes are wasteful are very compelling reasons to wait until 5k.
5k isn't the upper limit either. If you commute every day on the freeway you could very comfortably go 6-7.5k without causing any harm to you engine. For you skeptics out there, European cars are going to very long drain intervals, with the car manufaturers blessing. You can buy these same oils here. Your oil will last beyond 3k but while you're at Iffy Lube waiting to see if they put in the right amount of the correct oil, strip out your oil pan, fail to put on the crush washer or try and sell things you don't want or need, I'll be having a double pepperoni pie.
