Rsx type R engine Swap Air/fuel ratio sensor wiring.
Old Nov 10, 2003
joedc5's Avatar
joedc5 is an unknown quantity at this point
Hi, I have an rsx type r conversion in my civic(check out the pics) My check engine light is
on because I needed the right o2 sensors(rsx). I wired up the Secondary 02 Sensor and
everything matched up. I had hasport do the wiring but something is wrong. I installed the RSX Primary 02(air fuel ratio sensor) and I can't figure out where the wires of the connectors are suppose to plug into. I looked in a honda ETM and notcied that the colors hassport put in the harness for the connector for the primary 02 do not match up with 2001 civic colors nor the RSX. I need to know which of these wires are what and what they do inorder to plug into the rsx air fuel ratio sensor and match everything up for correct operation. Anyone have any advice? Or had there wiring harness done by hasport? Please note I have the type r not the type s but the wiring is the same and yes I had the ECU modified to not look for the RSX vtech pressure switch. Please help. Thanks, Joe
Old Nov 10, 2003
HondaLuver's Avatar
Its a celebration bitches!
all i can say is call hasport. maby some one here who has done the swap can help you, also you posted inthe wrong fourm, this should be moved to swap/FI
Old Nov 10, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
i can't help u but damn..nice swap!
Old Nov 11, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
damn, rollin in money, are we?...
haha ... I wish I could do that ... STUPID CALIFORNIA AND ITS STUPID SMOG LAWS
Old Nov 11, 2003
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
you have a type r swap...and you call it vtech?...ouch.
j/p.
I dont know how to help you out... i wired my o2's in myself, they worked just fine. Thats HASport for you though.
Old Nov 11, 2003
double post i know, shut up! but i had a question for you joedc5. Why do you have the cruise control unit still on your car when the R motor doesnt have cruise control? didnt feel like taking it off? Like i said when i rated that pic...that swap needs to be cleaned up.
Old Nov 11, 2003
joedc5's Avatar
I finally figured it out. I went and got the three wire diagrams and did some rewiring. Took 4 1/2 hours but the car runs great and is no longer in limp mode so it really gets up and goes. Oh sorry for calling iy Vtech I know it's ivtech but really who cares. The swap does not need that much cleaning up and really isn't that messy from what I've seen. Also that is pic from about 2 months since then I have done alot of work and will post more pics after this winter with the turbo installation.
Old Nov 11, 2003
Voiceofid's Avatar
End Bringer
you should be glad, because it saves your life, there is a reason why the smog laws are so tight in ca
Old Nov 11, 2003
Green Civic's Avatar
The proper name is i-vtec. Sweet. Im thinking of doing the type-r swap. I need to check the law about jap swaps and stuff.
cloudguy
Apr 28, 2015 05:02 AM
TaiChi
Dec 17, 2001 09:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
Ichiban
Nov 18, 2001 12:13 AM
Vtecpwr
Nov 11, 2001 10:17 PM
