can a amp blow an altnator?
Old Aug 24, 2003
khmaitiger's Avatar
khmaitiger is an unknown quantity at this point
can it? it hink i blew mine.... like right after i installed it.. the check engine light is on now
Old Aug 24, 2003
Dr5D's Avatar
if your alternator is bad you need to get a new one ASAP, otherwise you will just stall in the middle of the road
Old Aug 24, 2003
WhiteRabbit's Avatar
it can happen, but it rarely rarely happens.
the only situation i know of it happening was a 2000 watt amplifier on a stock firebird alternator, and the first time he fired it up he did a bass burp and did zero to 170 amp draw in under half a second
but chances are, its not the amplifier that is makign the check engine light go on, more like an issue with wiring, or if you had the seat out and turned the car on, etc.
if something got unplugged or if you blew the right fuse, the light will go on.
Old Aug 24, 2003
khmaitiger's Avatar
my battery charge isnt goign up :-x 2 doesnt that mean its the alnator.. could it be because i have more than one amp?
Old Aug 24, 2003
khmaitiger's Avatar
its liek a 1 month old altanator 2, running amps that equal like 2600 watts max of amps
Old Aug 24, 2003
the vehicle E-system is strange like that, i dont think thats the alternator, ive noticed that in my car too, on occasion, staying at 12 and not bumping up to 14.
i dont think that alone is an alternator issue, i think that if thats your only problem theres gotta be another cause, but if you want to test that theory out, pull your power wire off the battery and drive around for a week or two and see how that changes your voltage.
the honda electrical system is the most finicky and odd electrical system ive ever seen, but if you have everything installed in a reliable way, then i dont see how the alternator could be at fault or how the amplifiers alone could cause that problem
Old Aug 24, 2003
khmaitiger's Avatar
o **** i forgot to say its not a civic its a chrsyler lol
sorrie but i dunno i was driving and then i smelled some elictracal burning so i turned off my system and then it went away and then i got home and noticed my check engine light on and my battrey gaugh really lower then it usually is
Old Aug 24, 2003
check yoru cable runs, you might have shorted something out, that might spike the voltage and cause the car to freak out.
unfortunately, i dont know enough about chryslers to give you a definite answer, but to give you the worst case scenario, you shoarted the power cable, and it traveled through the electrical system and burned some of your stock wireharness wires. this is an awful and expensive thing to happen/fix, but like i said its the absolute worst case scenario.
in this case, if it hit a non-vital system, like an airbag wire or other system, it should have been enough to fire the check engine light, or possibly a spike would have been enough to do so. meanwhile, the shorted wire might have been enough to kill the battery and not allow it to hold a charge. my batter for sure is on its last legs, i predict all my problems will go away on the purchase of a new battery.
but for sure i would have a diagnostic done, find out why that check engine light clicked on, the computer should save the fault it found to fire it off, who knows, maybe it was something stupid that fixed itself.
but for sure id start with that check engine light and chase it by tracing yoru powerwire through, as well as checking the stock e-system wireharness for burns. you smelled something burning? find it! theres your source of the symptoms....
Old Aug 24, 2003
khmaitiger's Avatar
lol ah icic i jsut figured it was my altnator or sumthing buring.. i unhooked the fuse to the amps and it still came on and stuff... i also noticed my oil pursuure gagage runing really high od persure thinks for the help tho white rabbit
Old Aug 24, 2003
khmaitiger's Avatar
iw oudl liek to add that i started the car liek 5 times now..s o that prolyl means its nto the altanator
Old Aug 24, 2003
cambo's Avatar
I wish I was asian
i would like to add that you need a spell checker.
or a dictionary.
imp:
Old Aug 24, 2003
khmaitiger's Avatar
stfu
its the battery!!! hahaha i put it on a charger and noticed that if i went from 2 amps to 10 amps charger thingy it woudl stay the samE! thefore it wont hold a charger higher then that! but that still doesnt explaion the check engine light
Old Aug 24, 2003
khmaitiger's Avatar
my self theory is that the battery wont hold a big enough charge so therfore it wont power oen of the amin systems fully thus causing the stupid engine light light being on
Old Aug 24, 2003
you yourself said you smelled burning electronics.....
im glad to know you isolated it as a battery problem, that confirms what im doing is the right way to go too.
however, the burning electronics and check engine light are still a couple of really big issues you gotta take care of, all teh worse if they are related....
also to track down teh source of each, you dont want it happening again!
Old Aug 24, 2003
cdmx's Avatar
coo, i was about to tell you it was the battery..:-P glad you found the problem
Old Aug 25, 2003
khmaitiger's Avatar
aight geuss waht i took it to firestone and my atalnator went bad but because they saw that the sound system was there they balmed it on that! i shoulda tooken it out frist but o well. cant complain i woulda done the same thign if i was firestone
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Mc7602
Sep 17, 2015 02:01 PM
