maint. required light?
Old Aug 15, 2003
berettagtz117's Avatar
berettagtz117 is an unknown quantity at this point
My Maint. required light has been on since about 8000 miles now on my 2002 Civic EX and it is currently at 8650. I tryed pulling ecu fuse and disconnecting the battery and that did not make it go away does anybody have any idea what it might be or have the same problem please let me know thankyou to all.
Old Aug 15, 2003
ANYBODY?
Old Aug 15, 2003
RunawaySoul's Avatar
RunawaySoul is an unknown quantity at this point
The manual will tell you how to reset it. It's quite simple but I forget how to do it. If it's still on then you have a problem then.
Old Aug 15, 2003
neocivic01's Avatar
the Rage
neocivic01 is an unknown quantity at this point
i went to the dealer after my light would not turn off, he said that means i need an oil change, i told him that i changed it myself recentaly. so he said ok i just need to reset your comp.
Old Aug 15, 2003
wonderz's Avatar
wonderz is on a distinguished road
ok, this is early in the morning and I am taking a break from cramping for my exam. and I don't wanna be one of the ppl that just say search and leave u hanging.
but next time u should really read that manual, it takes less than 5min.
reset the indicator as follows:
1. turn off the engine.
2. press and hold the select/reset button in the instrument panel, then turn the ignition switch ON(II)
3. hold the button until the indicator resets (approximately ten seconds)
side note: you don't have to start the engine, just turn to the II position. (you can see there are 0, I, II, II written around the "key hole" if you don't know what i am talking about). also wait until the indicator turn off to release the button, it will be the last thing that goes off. the select/reset button is that thing that sticks out of the gauage, and its the one on the right hand side.
EDIT: those instructions are for a USDM civic, just read your location and it said Germany. So not sure if it will work for UKDM
Old Aug 15, 2003
skipbarber's Avatar
search
Old Aug 15, 2003
Thankyou WONDERZ it worked like a charm no I now for future reference..
Old Aug 15, 2003
robbclark1's Avatar
Retired suspension supermod.
You guys should read your manual more often. You know that book they give you at the dealer??
Old Aug 15, 2003
dezod's Avatar
7thgen Power Maker
Good lookin out wonderz
Old Aug 15, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
Perfect post at the perfect time.... My light just came on for the first time - thanks wonderz.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
TropiKalCiviC
Nov 8, 2001 10:13 PM
