Header Controversy
Old Aug 14, 2003
Dr5D's Avatar
Header Controversy
I did a search
Everything I found was, well, unclear.
First off I’ve got the EX 5speed.
I always assumed that the HP header was the best, but some say Kamikaze?
It was confusing because people are changing other cuts to an EX.
I guess one is better for one cut and the other is better for - the other.
Then I see that there are 2 different HP headers, though I guess the one that also replaces the cat/down pipe is better. Witch raises another question that I didn’t have before, are the down pipe and the cat the same thing???? I didn’t think they were...
I have no emission tests where I live so that’s not an issue, I just want the best gains from a better header (bought impulsively before), down pipe, and cat.
I would love some help, searching actually confused me more!
Old Aug 14, 2003
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
i havent had either of them, but judging by what i have read, theyre pretty much the same. i personally am just not doing a header and going turbo.
Old Aug 14, 2003
Dr5D's Avatar
im not going to go down the F/I road, personally i think its too hard on the engine
Old Sep 7, 2003
Dr5D's Avatar
Dosent anyone know?!?!?
Old Sep 7, 2003
PunkingCivic's Avatar
I need TP for my bunghole
The down pipe is empty tubing.
The cat has stuff inside of it for polution filtration reasons.
So to answer your question ,the down pipe will given more power because there is no blockage (meaning no back presure) =ing more power.
Old Sep 7, 2003
Bjmayo523's Avatar
Bjmayo523 is an unknown quantity at this point
Actually if you go to MMRUSA.com they have powercore headers and race cat for our car's. The cat also includes the downpipe that is welded to the cat, so you know it is the correct one for our cars. you should check it out.
Old Sep 7, 2003
Dr5D's Avatar
hey thanks for the tip man. I dont think I have ever heard of that place or header before, Ill def go and check that out!
Old Sep 7, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
Well.. i just picked up some info on this because i bought the kamikazi header and high flow cat (the real ones) from bigjoshracing... basically the setup i got was just the upper portion of the header, and a high flow cat.. the downpipe is the missing link between these two... the downpipe comes before the cat, at least on EX's. If you get the HP one, they give you the whole set, if you do individual pieces, then you'll have to get a downpipe from somewhere else, or get one made.
Old Oct 4, 2003
fennel123's Avatar
fennel123 is an unknown quantity at this point
this powercore header- do u need to take that thing off which makes you car fail emissions?
Old Oct 5, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
The hp race header w/hi flow cat is a 4-1 design, there is no "downpipe" it is all one piece. On the stock header you have the header itself, which bolts to the downpipe (collector)which i belive is welded to the stock cat.
The hi flo cat is a straight through design, freeing up the most HP. With the 4-1 w/hi flo you are losing some low end torque but when your in the powerband your getting maximum flow. The piping is much bigger than stock and i must say that it is the best performance mod i've put on. (unless your going turbo, then well you won't need a header) The hi flo cat isn't legal, but if you dont have emissions its great. If you do, you can have a muffler shop cut the stock cat off the downpipe, put a flange on it and you can swap out your cat's for inspection day!
And it will pass visual inspection, unless they actually unbolt it. (which they wont do) so if you get your motor piping hot before you get it inspected, it will probably pass w/ the hi flo in there.
good luck.
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
