help again
Old Jul 6, 2003
dankooms's Avatar
dankooms is an unknown quantity at this point
help again
anyone now if a 19mm rsx sway bar needs the brakets or bushings in order
for it to fit on a 2002 si civic canadian? or do i just need the bar?
Old Jul 6, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
you're going to need some brackets. i don't know about bushings. i don't even know if that bar will fit correctly.
Old Jul 6, 2003
GreenNVicious's Avatar
Newbie
ask the guru, Grey, about it.
Old Jul 7, 2003
Weaponx12o's Avatar
the civic Si in Canada is the same as a civic EX here in the US, so it should fit with the stock brackets you have right now. you probably only need just the bar. everything should fit with the stock parts. double check to make sure though, i might be wrong
