Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
bouncing idle and misfire at idle
Old Nov 11, 2009
sunnyside1's Avatar
sunnyside1 is an unknown quantity at this point
Question bouncing idle and misfire at idle
alright i need some help with this problem...92 civic with 98 motor 1.6 sohc. car missfires when first started up for like 30 to 60 seconds. after that its fine it will idle at about 1200. After warmed up the idle starts bouncing from 900 to 1300 repeativly. so i turn the car off and turn it right back on it will idle steady at 900. So i was like cool problem solved but when ever i turn my lights on it starts doing that crazy bouncing idle again but it runs good. i cleaned the fitc and the iacv valve,new plugs,wires,cap,rotor, but i cant seem to find the problem. bad ground maybe?
Old Nov 11, 2009
Re: bouncing idle and misfire at idle
vacuum leak? check all the lines for cracks.
Old Nov 12, 2009
94pos's Avatar
94pos is an unknown quantity at this point
my 94 civic w a 1.5 ltr is doin the same thing, idles up to 1300 n drops bak to 900? wat do i look for first?
Old Nov 12, 2009
could be tps sensor gone bad. replace the throttle body, theyre only $50 on ebay
Old Nov 16, 2009
lilytek's Avatar
lilytek is an unknown quantity at this point
could be a lot of things. I would check idle air control valve. Somtimes cleaning that will take care of the problem, I had similar symptoms on mine and that solved the problem.
SimpleUser
Apr 24, 2021 02:54 AM
martinsmartin
Aug 15, 2015 07:34 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
Dani1993
Jul 24, 2015 09:02 AM
NROD315
Jul 21, 2015 07:46 PM
