Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
purchasing replacement battery Civic 2dr VP 2005 1.7eng
Old Sep 8, 2009
PeteReview's Avatar
PeteReview is an unknown quantity at this point
Talking purchasing replacement battery Civic 2dr VP 2005 1.7eng
Civic 2dr VP 2005 1.7 engine - Costco has a battery for $55 and dealer is selling for $100. They are both 51 size - but CCA is 200 higher on Costco's battery than Honda. Which is best to buy? Thank you
I read higher CCA can cause problems. Does it have it have to spec match exactly to be the right one?
Old Sep 8, 2009
Re: purchasing replacement battery Civic 2dr VP 2005 1.7eng
higher cca cause problems? just the opposite. im using a 500 cca autocraft battery and it works great (oem is only 420 i think). dealer sells a group51 battery with 500cca too i believe. the more cca the better
Old Sep 11, 2009
PeteReview's Avatar
Thumbs up Re: purchasing replacement battery Civic 2dr VP 2005 1.7eng
Thank you Gearbox. I have changed batteries in the past on much older cars. So all I got to do is input radio code after changing battery? I got the code on little card that came with the manual.
Is there more to it? Thank you in advance!
Old Sep 11, 2009
the ecu tends to get a bit messed up since it has to relearn all the fuel trims and stuff and it takes a while for that maybe a tank of gas. best and easiest way is get a battery saver from walmart which is a cig lighter socket that you plug to the car and connect to a 9v battery. turn the car to acc position to energize the socket, that way your radio and ecu settings are saved when you disconnect the battery. be sure not to use anything electrical like dome lights and stuff cause the 9v cannot do anything except keep the memory settings from disappearing.
Old Dec 2, 2009
PeteReview's Avatar
I followed your advice and works like a dream. I installed it right in the parking lot at Costco since the old battery must be returned. Walmart also had those cushioned rings and protector spray. The cushioned rings act like a sponge and holds the anti corrosion liquid on the terminal like jacket. Thanks again gearbox.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
tylerginevan
Apr 27, 2015 12:29 PM
twtron
Apr 17, 2015 12:09 AM
smmahan
Apr 15, 2015 08:17 PM
thesushiboy
Apr 12, 2015 02:54 AM
