02 EX hard to shift into 4th and 5th
Subscribe
Mar 31, 2009
I have a 02 Civic EX and when shifting from 3rd to 4th or 4th to 5th it is very difficult. Feels very gummy unless when shifting from 3rd to 4th I first put it in neutral and wiggle the gear lever then it will shift smoothly.
I have seen the Honda service bulletin releated to this and already replaced the shift cable bushings but that made no difference. Anyone had or know of this problem and a possible fix?
May 31, 2009
Re: 02 EX hard to shift into 4th and 5th
Dude - I'm having the same problem, but with 3rd & 4th.
Anyone?
...also an '02 EX.
Oct 11, 2009
I'm having the same issue. I have changed the transmission oil which seemed to help a little but didn't solve the problem. Does anyone have a solution?
Oct 11, 2009
01 lx But mine only seems to do it in the winter or on colder days. Has me stumped....
Jan 12, 2010
Change your cable bushings and shifter bushings.
Twmperformance.com
or
strutking.com
Jan 22, 2010
I had a similar problem, does it grind just a little bit when you push it into the gear when you shift?
Jan 22, 2010
syncro issue?
Subscribe
