Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Help, my Car is not working properly, less power, consuming more fuel.
Old May 27, 2008
Josue1983's Avatar
Josue1983 is an unknown quantity at this point
Hi everyone,
I want to thank you all for this forum, now I would like you to help me, because my car doesn't have power after started, when the car is cold it's ok, but after 10 mins, when I stop and start again, I have to revolutionise more than necessary the car to have a good start, and it's harder when I am on a hill, I need to put the handbreak, revolutionise it, then it starts with low power. Another issue is that it consumes a lot fuel and besides it has extrange sounds, like little hits under the car, but I have checked it and it doesn't have anything wrong. All these issues started after I took my car to the mechanic to check everything. If you can give an idea, I could take my car to a good mechanic telling him exactly what is the problem.
Thank you all for your help!
Old May 27, 2008
Re: Help, my Car is not working properly, less power, consuming more fuel.
sounds like maybe bad oxygen sensor, or clutch going out too.
Old May 28, 2008
chinaman's Avatar
chinaman is an unknown quantity at this point
Whats the year, make, modle of your vehicle and is your check engine light on?
Old May 29, 2008
Josue1983's Avatar
Hi, thanks all for your replies, the Car is Honda Civic Model 95, LX Sedan, and yes, when is turned on the check engine appears on but when starts the motor, that check engine turns off. All these problems started after I took my car to the mechaninc, and I could guess it is the clutch, but it can also be the oxygen because that problem didn't happen before... :S
Old May 29, 2008
93BlackCivic's Avatar
93BlackCivic is an unknown quantity at this point
id say to check out the sensor first and if its an automatic then check the transmission because if its loosing power then the tranny might be to fault and if the check engine light comes on then that could also me the transmission... also for the gas problem it could be both the sensor and fuel pump... check the sensor first because if its idol is terrible that means the sensor is out and will cause the fuel pump to fluctuate
Old May 30, 2008
shortys1519's Avatar
shortys1519 is an unknown quantity at this point
it could also be a headgasket. i just replaced mine and it was sounding like thumping and sputtering in the exhaust and engine. and i lost a ton of power from the car and the gas went down too
Old Jun 3, 2008
Josue1983's Avatar
Hi, Thank you all for your help!
Now my car is working correctly and the problem was with one of the injectors that I had to replace, and now it has the right power, Thank you all!
roverben
Jan 21, 2019 05:16 PM
mattdoc
Mar 14, 2017 12:10 PM
tylerginevan
Apr 27, 2015 12:29 PM
Blaster30
Apr 22, 2015 12:21 PM
Jonas Powell
Apr 16, 2015 11:47 AM
