Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Vtec-e
Old Apr 8, 2006
Jimmy J-spec's Avatar
Jimmy J-spec is an unknown quantity at this point
Vtec-e
If u any of u guys kno wat a vtec e motor is let me kno. thanks
Old Apr 9, 2006
GoneIn60's Avatar
GoneIn60 is an unknown quantity at this point
It's Honda's next version of VTEC, VTEC-E, was used in a slightly different way instead of optimising performance at high RPMs, it was used to increase efficiency at low RPMs. At low RPMs, only one of the two intake valves is allowed to open, increasing the fuel/air mixture in the cylinder which allows a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, as in the regular VTEC, is used to connect both valves together and allows opening of the second valve.
Old Apr 11, 2006
thanks man, so it shouldnt be used as a performance engine? and with what you said about the low rpm thing, does that mean it wont get past a certain rpm?
Old Apr 11, 2006
GoneIn60's Avatar
yea from what i read about it its seems as more of a fuel efficient engine and probably wouldnt be a good choice for a performance engine. The low rpm thing basically means that it uses one valve to save fuel until higher speeds when both are used
Old Apr 14, 2006
so wat type of computer should be used if i have a 97 vtec e engine.
MindBomber
Engine Swaps
Mar 12, 2021 10:12 AM
Bonnabell
Aug 14, 2015 04:15 PM
sdaidoji
Jan 25, 2014 11:42 AM
goodtimes
Jan 7, 2006 02:08 AM
Gryphin
Oct 19, 2002 10:32 AM
