Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Help!!!!
Old Aug 12, 2003
danscreations's Avatar
Tuckin' 19's
danscreations is an unknown quantity at this point
Question Help!!!!
Does anyone know if the SI had a suspension change from 01 to 02? In particular I'm tiring to find out exactly what size mm bolts connect the bottom of the strut to the rotor/brake assembly. See picture below:
I think the 01's are a 14mm bolts and the 02's are a 16mm bolts.
Old Aug 12, 2003
Spider883's Avatar
9K Redline Owns U
all 01 and up civic and 02 and up si's and 02 and up rsx have the same 14mm
Old Aug 12, 2003
civicvtec1ps's Avatar
Search and Learn
i know rsx. and si has 16mm bolts..im pretty sure 02 and 03 uses same bolts.(there is no 01 civic si)
Old Aug 12, 2003
Green Civic's Avatar
14mm bolt. 02 and up SI. No 01 SI. 01 and up civic.
Old Aug 12, 2003
Tuckin' 19's
LOL...everyone seems to have there own opinon or guess. Dave (Spider883) has actually installed the 14mm SPC cam bolts on his new ep3 out of the coupe he had. I beleve! Has anyone else put the 14mm bolts in there SI, and the same goes for the 16mm. I'm hoping someone who actually has installed the front bolts on there SI will post so we can find out.
P.S. sorry for refering to an 01 SI I had no idea I have a coupe so....
Old Aug 12, 2003
ep3guy's Avatar
ep3guy is an unknown quantity at this point
The bolts are 16mm for both the 02 Civic Si and the 03 Civic Coupe.
Parts for 03 Civic Coupe
That is the part listing for the 03 Civic Coupe.
Parts for 02 Civic Si
That is the part listing for the 02 Civic Si.
As you can see, they are both 16mm.
Old Aug 12, 2003
Tuckin' 19's
Alright, then let me start a list and you finish it or correct it:
Civic Coupe & Sedan
01 = 14mm
02 = 14mm
03 = 16mm
Civic SI
02 = 16mm
03 = 16mm
Old Aug 12, 2003
ep3guy's Avatar
Go to those websites I just posted above, and then change the type/year of the Civic. It will tell what you what size bolts are needed.
Here are the part numbers that I will need.
Here are the part numbers: 67230 Rear / 81280 Front 16 mm
Please send me the correct kit.
Old Aug 12, 2003
Search and Learn
Civic Coupe & Sedan
01 = 14mm
02 = 14mm
03 = 16mm
Civic SI
02 = 16mm
03 = 16mm
that seems correct dan
Old Aug 12, 2003
Tuckin' 19's
YEAA!, now I have to redo the website...lol!
