60,000 mile maintenance 06 Civic Hybrid
Old Jan 30, 2012
devcivic87's Avatar
devcivic87 is an unknown quantity at this point
New to the forum I usually search for answers instead of posting new threads but figured I would post one anyway, since I am looking for more specific answers. My 06 Civic Hybrid just hit 63,000, and I am wondering what type of maintenance you would recommend, and if you think it would be ok for me (ok ok not me, my fiance!!) to do it at home. We talked to the dealership and they said it'd be like $400 to do this whole laundry list of things, but I take really good care of my car so I dont think I would need to do every little thing. I use synthetic oil, we do the oil change in the garage, thanks to a super handy post on here! I'm not hard on the brakes though I probably should check them, theyre a little squeeky... I definitely dont have $400 to spend right now, so what are the small things that are important that I should really consider doing? Thanks in advance!
Old Jan 30, 2012
Re: 60,000 mile maintenance 06 Civic Hybrid
Read your owners manual.
Maintenance minder.
Make a list of what has already been done and when it was done.
See what is coming up to be done soon.
Compare lists.
Do whatever hasn't been done yet.
There isn't much.
Oil changes
Trans fluid- I would try to do every 30k
Air filter and Cabin filter
Brake fluid every 3 years
Care for the tires if needed-maybe rotate, maybe balance, maybe alignment.
Inspect the rest of the car as necessary.
Old Jan 30, 2012
devcivic87's Avatar
Maintenance minder.
Compare lists.
There isn't much.
Oil changes
I mustve sounded like a ding-dong, I should have mentioned I dont have a manual. Lets just say thats not the only thing the dealership forgot to mention when I bought the car...
Definitely seems like all of those are doable.. except for the cabin filter. Is this something I should have a body shop do? I am afraid the plastic will scratch easily
Old Jan 30, 2012
Easy. The Honda site.
http://automobiles.honda.com/informa...resources.aspx
Google.
This should be real similar
http://www.filestube.com/clKtdJBVj2P...ic-Manual.html
http://www.filestube.com/5d5d5a75d4c8814c03eb/go.html
Or google Honda maintenance minder.
The cabin filter is super easy. Open the glovebox. Empty it. Squeeze the sides in. Open the glovebox farther and let it drop. The filter tray is right behind it, opens like a drawer. Should be obvious.
Old Jan 30, 2012
devcivic87's Avatar
Google.
Sweet!! Thank you!
Old Jan 30, 2012
Oh crap. I didn't search for a Hybrid manual. You might have to google for yourself or just order one from the Honda site.
Old Jan 30, 2012
devcivic87's Avatar
I think I will order one. Theyre pricey but I definitely need to have one on me. No manuals, no tire iron, and car had been in a wreck which they neglected to tell me. Go figure!
Old Jan 30, 2012
devcivic87's Avatar
BTW just YouTube'd the cabin filter... lol piece of cake! Im sorry I even asked
Old Jan 30, 2012
This is stuff you (or someone) should have noticed before you bought it.
A pre-purchase inspection by a mechanic you trust can be quite valuable. Can give you bargaining power at the time of dealing, or save you a headache altogether.
Might as well check and see if it even needs the filter yet before buying one.
Old Jan 30, 2012
devcivic87's Avatar
First-ever car purchase on my own, you live and you learn. I bought it in 2009 and havent replaced the filter (either one) so I am sure they would benefit from a swap. My allergies will thank me for changing the cabin one anyways
Old Jan 30, 2012
And use the correct factory fluids. I don't care if they are pricey.
The trans is simply drain and fill.
A manual trans is tricky to fill.
If it is a CVT it gets special CVT fluid.
Old Jan 31, 2012
devcivic87's Avatar
Good to know, I will, thank you. I found the PDF manual for my car, the tranny fluid looks like a piece of cake. I will get Honda brand, the guy at the dealership quoted me $8.25 per bottle (said it would take 3)
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
inarschenk
South
Apr 18, 2015 04:29 PM
dooner24
Apr 14, 2015 07:51 PM
