gas smell
Old Sep 9, 2010
rigo1973-1's Avatar
rigo1973-1 is an unknown quantity at this point
gas smell
guys i have some problems with the swap b16a check engine light is on the code is map sensor but that engine don't have one or i can not see it is not on the throttle body or in the firewall the engine that the car had before the swap had it on the throttle body this b16a only have one connection for it tps no map can some one help please the car is running rich i can smell the gas from far the icv was clean, new spark plug,new wire set,cap,rotor,oil, filter,i order a new tps not here yet please help
Old Sep 10, 2010
MelJ's Avatar
Trance Addict
Re: gas smell
May sound silly, and I apologize, since I'm just waking up. Is everything bolted onto the throttle body securely? I removed my intake once and didn't tighten it fully and my car threw a code and I smelled gas. Tightened everything up much better and reset. No issues afterwards.
Old Sep 11, 2010
rigo1973-1's Avatar
Re: gas smell
thank you no i did not loosen any bolt but thank you
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
WaryDriver
Aug 22, 2015 06:50 PM
GritzNGravy
Aug 19, 2015 03:03 AM
