I smell gas!!!
Old Aug 2, 2010
yeyasoyyo's Avatar
yeyasoyyo is an unknown quantity at this point
Unhappy I smell gas!!!
Hey just wondering if any one might know if the gas regulator might have something to do with it. I have a 97 civic 4 door
Old Aug 2, 2010
wdeguire's Avatar
wdeguire is an unknown quantity at this point
Re: I smell gas!!!
do you smell it while starting, parked, while driving, is there change in performance?
Old Aug 2, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
i smell it when i start my car after i drive it parked its pretty much a constant gas smell.I checked the fuel pump to see if it was on right or tight it was.
Old Aug 2, 2010
Re: I smell gas!!!
fuel pressure regulator?
Old Aug 2, 2010
wdeguire's Avatar
Re: I smell gas!!!
fuel pump is located under the spare tire in the trunk is that what you checked?it could be a leaking fuel feed or return line and or fuel injection system maybe the evap system is clogged.. any engine codes?
Old Aug 2, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
man this is flying over my head no i cheked under my back passenger seat.
Old Aug 2, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
i guess so IM just gueesing at what could be the problem so i dont get jipped at the repair shop.
Old Aug 2, 2010
wdeguire's Avatar
Re: I smell gas!!!
mine being a hatchback it could have been the pump you checked..not familiar with the 4 doors but if its above your gas tank then sure. but it could be as simple as just a loose or leaking hose somewhere. any spots on the ground? do you lack performance?
Old Aug 3, 2010
01civiclx94's Avatar
01civiclx94 is an unknown quantity at this point
Re: I smell gas!!!
Are you loosing any power from it
Old Aug 3, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
what does that mean? It prob sounds like a dumb ?
Old Aug 4, 2010
Re: I smell gas!!!
i think he means, does the car drive normally or does it have problems accelerating
Old Aug 4, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
no it doesnt it a 5 speed if that makes a difference. Man i hate having a car especially an older one
Old Aug 4, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: I smell gas!!!
Prolly smashin the car so hard, u dont even notice a change in performance....
But anyways, drive it around for a while, then park it, look under the car and see if anything drips (oh, and dont use the AC)
And does it smell exactly like gasoline? (Like if you were standing at a gas station?)
or does it smell like OIL? (something like burning rubber smell)
Could be a gasket, or something in the exhaust if it's oil
Old Aug 4, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
ha ha ahh no and yes it smells like gas fumes strong by the rear driver side its really getting to me i cant figure it out
Old Aug 4, 2010
Kenny the Ricer
Re: I smell gas!!!
Might be a gas leak, either by a crack, or loose hose or something
Check for drips
also, do u notice your gas mileage lowering?
Old Aug 5, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
yes i do
Old Aug 5, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
im just going to put it off till this weekend
Old Aug 5, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: I smell gas!!!
What everyone suggested is right on, did you check that stuff?? I wouldn't take it to the shop because it might be really simple. Check the transparent hose connected to the evap canister, it is the black "can" under the fuel filter. But you need to determine if the smell is coming from under the hood or inside the cabin.
If it's under the hood, check the fuel filter, fuel rail (injectors attach to it), the return hose, what not.
Old Aug 7, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
ur post was really helpfull thank u uuuuuuuuu
Old Aug 7, 2010
yeyasoyyo's Avatar
Re: I smell gas!!!
where did u get the drawing from
Old Aug 7, 2010
Re: I smell gas!!!
It's from the official civic shop manual in .pdf.
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
WaryDriver
Aug 22, 2015 06:50 PM
GritzNGravy
Aug 19, 2015 03:03 AM
