Replacing Distibutor Rotor
Old Apr 28, 2007
echoes67's Avatar
echoes67 is an unknown quantity at this point
How do you remove the distributor rotor set screw on a 2000 Honda Civic DX four cylinder not VTEC with the plastic cover under the rotor blocking access?
It looks like I need to rotate the rotor to a point where the set screw lines up with an opening in opening in the plastic cover that would allow access with a screw driver. Is there someway to rotate the rotor?
Thanks.
bsmiley
Apr 27, 2015 01:27 PM
tattedlariat
Apr 12, 2015 07:55 PM
thesushiboy
Apr 12, 2015 02:54 AM
Grey
17
Feb 21, 2004 06:21 PM
domesticsnyper
Jan 8, 2002 11:29 PM
